Richie-Van-GTi
Name That Gasket
Richie-Van-GTi
Recently bought a genuine pug head set for a 205. Ive used all the gaskets relating to the gti and Im left with a few gaskets which I assume are from other 205's. Id like to see these go to someone that can use them as I wont.
Please try and identify them from the pics :angry:
Ryan
1st pic is a carburettor gasket
2nd pic looks like an exhaust gasket, possibly for a TU engine?
3rd pic looks like cam seals?
4th pic is gaskets for the mechanical fuel pump on some carb models.
5th pic I'd guess is for the thermostat and cover?
5150maxie
these are just a guess hope it helps i may be wrong on some.i had some like these left over when i have a full gaskets set.
1.inlet carb manifold gaskets for carb models
2.exhaust down pipe gasket for carb models
3.camshaft end seals
4.mechanical fuel pump gaskets for carb models
5.water distribution block gasket(back of engine at bottom pipes going to the bulkhead)
on rubbers in pic looks like thermostate housing rubber o rings.
Edited by 5150maxie
