Grahamrally
Whats It Worth?
Grahamrally
I have a Peugeot 205 rally car, originally bought as a 1294cc left hand drive car and the 1294 was ditched as it was beyond repair at the time for a GTI lump. Put aside any results I may have had that may increase or decrease value.
This isn't a for sale thread, or I'm looking to sell it in the near future, I'm actually after an average evaluation from anyone who wants to guess it's worth. I've not worked out what I've spent on it and definately not planning on either! lol
The shell isn't a new build, but almost every other mechanical component is. Tell me what you think is what it's worth?
Engine & Gearbox:
1905cc GTI engine
Richard Longman cylinder head (standard valve sizes)
Piper 285 cam
Twin 45 DHLA dellorto carbs
NGK spark plugs
New Liners and pistons
Tolerance checked rods
Fully balanced and lightened bottom end
ARP rod bolts
Saunders Motorworks reground crankshaft with oversized bearings
Group A oil pump
TI Motorsport Baffled sump
Megajolt ECU
Ford EDIS4 ignition system running from TPS and trigger wheel
Mocal 13 row oil cooler
Baker Hard rubber gearbox and top engine mounts
Constella solid lower rear mount.
1.6 GTI gearbox with 4.4 CWP (Mi16) rebuilt with new synchros
1.6 GTI drive shafts
Kaaz lsd
OMP 4 paddle racing clutch
Lightened flywheel
Quickshift gearlinkage quadrant
Xsport motorsport quickshift gear lever
Xsport motorsport adjustable gear rods
850 kg
155 bhp @ 6500 RPM
130 lb/ft torque
Shell:
Reinforced suspension top mounts
Tank guard foam filled
Forest sump guard
Reinforced bulkhead around pedal box
Strut brace
Safety devices 6 point bolt-in roll cage
Lexan side and rear windows
Fibreglass boot and bonnet
Lightened doors with aluminium door cards
Suspension:
Front:
Xsport motorsport reinforced subframe
Bilstein tarmac adjustable platform coilovers 300/200 insert
Eccentric rose jointed top mounts
PTS top mount spring pan for rose joint top mounts
PTS 225lb springs
TI Camber adjustable rose jointed bottom arms
Fully poly race bushed front suspension
Rear:
West Midlands Motorsport Group A mounts
21mm PTS torsion bars
24mm PTS Anti Roll Bar
Bilstein tarmac shock absorbers
Brakes:
West Midlands Motorsport bias adjustable pedal box with dash adjuster
Rally design vertical lever hydraulic handbrake
Wilwood rear brake bias valve
Hi-spec 4-pot racing calipers 285mm rotors and aluminium bells
Pagid RS-4-2 blue pads
Mintex 1144 rear shoes in standard 1.6 GTI drums.
Other:
Corbeau Revolution seats
6 point TRS harnesses
Momo snap off steering wheel
1.75 litre Zero 2000 handheld
2.25 litre AFFF plumbed in system
Quick rack steering
Terraphone professional intercom
West Midlands Motorsport 2 1/4 exhaust (99db)
Co-drivers footrest
Momo pedal extensions
Ripspeed steering wheel
1.9 GTI wheels
Indy cut click 205/50R15 tyres x 6
Colway Intermediates 185/55R15 x 5
Michelin slick tyres 15 x 4
Le man oil/voltage/oil temp gauges
Hub stud and nut conversion
My guestimate is 5-6k perhaps.
Edited by Grahamrally
johnrobertgordon
Tidy! :)
ORB
Ohhhh, that looks a bit Zoooom!!
Grahamrally
Thank you fellas! It wasn't that tidy when I got it! It looked awful and I got ripped off when I bought it. Here's a pic:
but what do you think it's worth?
johnrobertgordon
Its difficult to say, its never going to be worth what its worth to you. Best way to get at least a portion of your money back is to break it.
Is it log booked?
Grahamrally
As I said in the original post, this is more for evaluation, I'm not looking to break or sell it etc. Yes it's a fully functional rally car, we're doing the Welsh Tarmac rally championship this year! Shall be great fun. May get it down to the PSOOC track day too.
johnrobertgordon
sounds like you have put a huge amount of effort and detail into it, bet she's a quick little car.
