Spiky
Fuel Filter Leaking :(
Spiky
just cant stop the fuel filter bottom banjo leaking :angry:
it was a brand new filter and new washers too :(
should i buy a new one and try again or
can i just the banjo's off the end and install a push pit fuel filter type????
luggy
Swap the bottom ones for the top, What about your old ones?. If all else fails theres always good old plumbers tape. Just make sure you dont overtorque and strip any threads.
Edited by luggy
Spiky
where you put the plumbers tape? wrap around the washer
luggy
Aye!
hengti
was it a non genuine filter and seals?
the pattern filters i've had have come with washers that are much wider (in outside diameter) than the genuine pug ones - the oe pug seals have had a much smaller o/d, which seems to help sealing
might help
Spiky
just checking, my filter came with 2 washers 1 big 1 small
but the one i took off had 4???
which of the below pics is correct?????
got mine from GSF?
should i get it from PUG????
hengti
ah ...
piccie on left is correct.
Spiky
so, as they only gave 2 washers. they fooked up
will get a new filter tomorrow then and make sur i have 4 new washers too
Spiky
just rememebred :angry:
i bought the fuel filter at a motor spares place, as it was before i relaised cardiff had GSF had a unit in cardiff
now it's all clear
i'll pop of GSF tomorrow, and get a new filter :(:o:D
hengti
the filter's probably fine (although the alloy casing can be relatively soft - you might have compressed the washer into it if you've overtightened it - this might not be be a problem if you have another go with washers with a smaller o/d though).
try your local Pug dealer in the morning - i *think* the copper washer part nos are 156256 (x2) and 156244 (x2).
they're crush washers, so you shouldn't really reuse them by the way.
Richie-Van-GTi
A little side note while reading about fuel filters. The Mk2 2.0 astra uses a similar filtyer, smaller in design, flows just as well and capable of the pressures etc but its setup so you just clamp the fuel hoses either end instead of using the banjo's.
