MiD 0 Posted January 5, 2007 I'm in the process of retro fitting electric windows to my GTi, have ordered the door pockets with switches and now need the electric motors. Someone is selling 309 motors and whilst I presume they are the same as the ones on the 205 I just want to clarify this is the case. Other than the pockets and motors is there anything else I need? I've checked the wiring loom is in the door to enable me to do this. Another issue is the heater fan. It has been making the usual bunch of spanners in a bag rumble. I took it off WD40 it and sounded wonderful for a day, unfortunately the noise is back. How do other people lubricate this, could I use motorcycle chain lube or is it a case of it 's too far gone and I have it replace it with a new one? Share this post Link to post Share on other sites
Super Josh 4 Posted January 5, 2007 309 motors will be fine. Just make sure they are from a 3 door. I got p!ssed of with my fan motor and bought a brand new one, on the assumption that they are all old and will fail sooner rather than later. I think that you need to remove the fan blades to lubricate it properly, sure someone who has actually done it will advise. Josh Share this post Link to post Share on other sites
Richie-Van-GTi 73 2 Cars Posted January 5, 2007 yep, you can remove the blades as its just a little push washer that holds it on but TBH if its rumbling then the bushes are worn in the actual motor and grease or oil is only gonna mask for short spaces of time. Either buy a known good one or go brand new. its part no 6441 59 from pug Share this post Link to post Share on other sites
Super Josh 4 Posted January 5, 2007 GSF part number T93456. £49.50 + VAT. Josh Share this post Link to post Share on other sites
