Spiky
Problem Starting My Pug
Spiky
yeah it's a nice leanring curve, as i've never owned one before.
can be much wrong now, as it's much better,
i'm thinking coil or fuel relay
futura
You'll need an early coil as rewiring for the new type would be too much hassle.
Good luck to you both -_-
Don't forget to change the oil as soon as you get them running right, all that cranking will have dumped loads of fuel into the bores and washed down past the rings into the sump.
Spiky
ok cheers
Spiky
got new oil and filter ready for when it's running -_-
