vern
Speedline Sl434 Wheel Bolts
vern
What bolts have people used with this type of wheel it looks like it uses a taper seat but I am not sure, as it looks like it could also use the standard flat washer type as it has a recess for washer.
Also what length are the bolts?.
Any info would be greatly appreciated so I can buy the bolts.
I'd imagine seeing as Speedline produce most, if not all, PSA alloy wheels that they'd use the same bolts.
can you take a picture of the hole?
Gentrix
just looked at the PTS Papers I have here, they say:
kone tapered bolts (hope it´s the right translation), with 31mm thread length and 90 Nm torque for tightening.
shine
You can use 12mmx1,25, 28 to 35mm thread lenght, 60 degr cone as used by most cars alu wheels
cybernck
to me it looks like you can use either a flat or a cone bolt ;)
sorry for the crap pic, had to adjust the levels to make the hole more visible.
vern
Thanks for all the replies.
Cybernck thats exactly what I thought, could use either.
I had searched the boutique site but found nothing useful.
Shine and Gentrix just what I wanted many thanks I can get these ordered now.
JERAM
you can use either type on the one's i have :)
Henry Yorke
There are group A ones that are meant to come with the wheels. Speak to carl cambers as he is in Suffolk (GKZ 206 on here or suffolk@psooc.com) as he bought a new set of these wheels but had to find his own nuts :)
vern
Jeram do you wheels look the same as the ones in the picture Cybernck posted?.
Carl Chambers
NOOOOOOOOOOOO!!!
Cant believe your in Suffolk and have the same wheels as me! :D
By the way I used the standard 1.9 wheel bolts and they were fine.
What colour 205 you got?
Will keep an eye out for it.
then let the tyres down :(
vern
I have a graphite grey cti with a TT conversion nearing completion, unless you live in the deepest darkest part of Suffolk (Lowestoft) you will not see me, as I do not get out much :D .
Carl Chambers
I live near Diss/Harleston on the Norfolk/Suffolk boarder which is about 35 miles from Lowestoft.
Let me know when its done and maybe we could meet up or something?
vern
Will do will let you know when complete.
JERAM
With 1.6 GTI wheel bolts.
