Guest BrainFluid
How Do I Go About Cobbeling Together A 1.9 Rear Beam
Guest BrainFluid
I'm totally fff ing fed up with this these rear beam and drum shaninigans I really got to do somthing about it.
A rear bearing failed on my car at 50mph yesterday, smoke, skiding and all. The heat and swarf have locked the hub nut to the axel stub...Big pisser...I doubt that it will come off without ruining the thread on the stub. And to be honest I dont really trust the metal now its metalurgy has changed so much it looks a very white grey. We will see but I rekkon it'll be off you come mr beam.
First off! A question about another 1.6 beam that I have.......
The drivers side was seized up. When the shocks and the torsion bar that runs through the middle of the beam were removed the drivers side seems to be as free as the passengers side, not seized at all. Does this mean that it was the torsion bar seizing?
There is no camber on either side btw.
I'm kind of hoping that I can grease it all up and put it back together. Probaly wrong tho. If so, and it has to be taken apart further....
...I'm well fed up with drums and If I'm going to have to totally rebuild this beam ASAP then what can I do about getting disks on there? Presuming the main beam itself is a okay what cars in the scrappy can I rob for the other bits from...ie disks & calipers from 306 etc.
Really would prefere to do this because I dont think I can trust drum bearings anymore. I actually have, dont ask me why, a brand new rear bearing and that looks well meaty and safer than a poxy taper bearing.
ANY help / suggestions would be very helpfull as I am a little bit at the end of my tether so i know I'm not thinking as straight as I could. It would be REALLY nice if you guys could help me get my head straight. I'm
I'm having a hard time even deciding what the hell is best to do and Searching for answers is just pissing me off, sorry, right now I need to start a debate.
Guest BrainFluid
  Quote
I'll put a wanted ad in regarding that too if it comes to it.
Henry Yorke
you never know how shagged your beam is until you have it in pieces on the floor. Mine was not that bad until i took it apart.
Not sure on pinching 306 rear disks and calipers etc, but i do know that 306 shafts fit in 205 beams, so possibly you can use the whole training arm in a 205 beam tube? This will come with brakes and the lot!
Alastairh
Well you'll need your donor beam (1.9/1.6)
Need a decent 205 base model beam tube. Suggest you strip them at the scrappy, and a pair of shafts, either of the base model or off likes of a derv 306.
make sure the base model beam does have an anti roll bar (not a early 205) and you'll be ok.
With a couple of hours scrounging you'll save ALOT of money :unsure:
Alastair
Guest BrainFluid
Two excellent replies. Thanks for the kick start.
Henry:
  Quote
Thats what worries me...Having thought about it I think the best thing to do is to dismantle both beams and see what there is to work with.
  Quote
so possibly you can use the whole 306 training arm in a 205 beam tube? This will come with brakes and the lot!
Can anybody confirm either way 100% ? Is there any PSA car that can be robbed for complete trailing arms to fit a 205 beam?
Alastairh:
  Quote
Well you'll need your donor beam. (1.6/1.9)...Need a decent 205 base model beam tube.
The beam tube will hopefully be one of the two 1.6 beams that I have. Trouble is, if it is to be a total rebuild then I'm just not going to settle for 1.6 Trailing arms, hubs brakes etc. I should have added 'out off a 1.6 beam' to the end of the title.
Thanks again.
Edited by BrainFluid
1. right, firstly the hub locking problem has nothing to do with the rear beams functioning in any way.
so just replace the bearing, and the stub axle that is runs on if it gets damaged (use a realllly big breaker bar on the nut, and a scaffold pole if that doesnt work)
2. this isnt a torsion bar (in its function) its the Anti Roll Bar, ARB for short.
It will prevent one side of the beam from moving a certain amount if its still connected to the other side, especially if you havent taken a damper off. The only thing the ARB is connected to is the other trailing arm, so if one arm is free to move and the other isnt it will hinder its movement to a certain degree.
When you took the damper and ARB off did you inspect the bearings of the trailing arm?
3. Discs and calipers off a 306 are identical to 205 and 209 units, as are saxo, 106, ZX. Xsara, even the 206.
The trouble is that its not this simple, you will need a disc specific stub axle, Hub and bearing, bracket that bolts to the trailing arm for the Caliper carrier, handbrake cables, brake lines, brake pads.
So its easier and cheaper to get a complete Disc braked beam.
As for wether the complete 306 trailing arm will fit I know it will, but I dont know what else needs to be done to make it fit, the trailing arm axle itself is the same as for the 205/309.
I'm also unsure about the bearing and hub, as well as the bracket for the caliper carrier, I'll check my Parts CD to see if anything comes up.
Edited by welshpug
Just checked, the caliper bracket from a 306 trailing arm has the same part number as a 205/309 unit.
couldnt find the stub axles though, and I cant confirm if the hubs would fit, but I think they will as they use the same bearings as 205/206/306/309.
just a case of getting out there with a tape measure and vernier calipers.
306/ZX arms will fit 205/309 beams fine, although obviously the 306/ZX tube, torsion and anti-roll bars are far too long.
Guest BrainFluid
Another two perfect replies. Thanks guys.
Welshy:
  Quote
The hub nut has had a stupidly large bar on it, an it will'ne budge...To much swarf and possibly welded together due to the extream heat...? Like I mentioned before the hub nut and axel stub has well changed colour to a nearly white grey! Would it be trust worthey even if I could get the hub nut off?
  Quote
A-ha!. I'm glad I slipped that in there to test whether I was correct about its name or not <_< . Thanks for putting me straight mate.
  Quote
Nope, when I took it off I was just starting to dismatle it without any urgency, When I look what should I be looking for?
Anthony:
  Quote
Ho ho ho! Great news, that has opened up possibilities to no end. I cant thank you enough man!
Thank you both once again! Theres light at the end of the tunnel now. :D
get a garage to what a rattle gun on it, then when you get it off just take your frustration out on it with a large hammer (i.e remove the old stub and stick a new one in)
before you go straight off and get some 306 trailing arms it'd be an idea to find what else needs doing before fitting them, i.e what length are they? do they alter the track at all?
the origional ARB should fit I reckon
I'm guessing that the torsion bars might fit?
  BrainFluid said:
A-ha!. I'm glad I slipped that in there to test whether I was correct about its name or not :D . Thanks for putting me straight mate.
technically you were right anyway as the anti roll bar IS still a torsion bar <_<
its just referred to as the ARB to differentiate it from the two 'main' torsion bars.
Guest BrainFluid
Whelshy:
  Quote
Gotcha. This could be the quickest solution. If I dont have to worry about fff ing up the axel stub shaft seen as it will be replaced... In that case the hub nut will come off by hook or by crook.
  Quote
before you go straight off and get some 306 trailing arms it'd be an idea to find what else needs doing before fitting them, i.e what length are they? do they alter the track at all...origional ARB should fit I reckon?...guessing that the torsion bars might fit.
Thats what I took Athonys word for*. Prehaps you could claifiy the matter Anthony?
jackherer:
  Quote
technically you were right anyway...its just referred to as the ARB to differentiate it from the two 'main' torsion bars.
Excellent. So its an ARtB then? <_<
*That they are the same as the 205's, that is.
Guest BrainFluid
Okay.
There seems to be enough posts regarding this issue at the moment.
Topic closed.
Many thanks to all replyeees, blessings to yourselves and families wot wot! <_<
Guest
