kent
Clutch Upgrade
kent
Started today to look on the clutch for my new engine.
All the details on nr2 side (look picture) is from a standard 405Mi16 and has 215mm clutchdia. and is press model. And nr1 that is more interesting has 235mm clutchdia and the flywheel fits perfectly. But the problem is the clutch and the bearing which is a pulling model. Then is the axle dia. in the clutch bigger :unsure: .
This clutch I think comes from an 605turbo, the flywheel unknown.
The simplest soluton would be if I found an another clutch with the right axle dia. and "pressure plate" that works with this 235mm flywheel press model.
Anyone have any good ideas anout this?
Regards Kent
