pugbliss 0 Posted December 28, 2006 odd problem rearly... head lights work normally with no probs but it all goes odd when i turn on full beam. looking from the front when full beam is turned on the driver headlamp goes to side light and the passenger spot doesnt light up, i have changed the bilbs but still nothing.. what do i do now????? Share this post Link to post Share on other sites
jackherer 543 Posted December 28, 2006 sounds like a bad earth... Share this post Link to post Share on other sites
pugbliss 0 Posted December 28, 2006 Mmmmm ok but where should i check?????? bit of a novice when it comes to sparky bits??? Share this post Link to post Share on other sites
jackherer 543 Posted December 28, 2006 take a look at the first two pics in this thread: http://forum.205gtidrivers.com/index.php?showtopic=68102 Share this post Link to post Share on other sites
pugbliss 0 Posted December 28, 2006 to be honest all that looks like isa big bunch of wires!!!! Share this post Link to post Share on other sites
jackherer 543 Posted December 28, 2006 Thats because it IS just a big bunch of wires There are two plugs behind the headlights, one each side of the radiator in some plastic covers. They are right in the middle of those two pics. Earth wires are green and yellow so they're easy to spot. Find them then do this (as described in that other thread...): Remove waterproof cover.Unplug cables. Cut ends off cables Re-terminate with Ring terminations Remove earthing block Bolt re-terminated cables to stud that once held the earthing block. Hey presto, lights brighter, horn and wiper washer work all the time! Do the same on the other side! Share this post Link to post Share on other sites
welshpug 1,662 Posted December 28, 2006 also clean up or replace the yellow connectors for the spot lamps. Share this post Link to post Share on other sites
Paintguy 0 Posted December 28, 2006 I had a very similar problem recently - one headlight would only work on dipped, and only one driving light would work. As I expected, it was due to bad earths in the places mentioned above Share this post Link to post Share on other sites
