James_m 0 Posted December 26, 2006 Right, i was wondering if anyone can recommend an easily availible sealent, specifically for exhaust manifolds. I had planned to use 2 Standard metal gaskets(this is with a QEP reangling wedge on an mi), but today i realised the bolts are too short doing it that way, so thats £50 wasted on gaskets (btw, if anyone wants one give me a pm) PeterT recommends loctite copper maxx, but looking on google i cant find much reference to it in the uk, and i need something i can buy right away. What has other people used and was it effective? Any input would be apreciated, Cheers James. Share this post Link to post Share on other sites
welshpug 1,662 Posted December 26, 2006 (edited) I cant remember the manufacturer but on my friends 200SX we used a red silicon type stuff (specific to fitting exhausts) on the turbo elbow while the gasket was on order. it was still intact 3 weeks later when we got round to changing it, and was pretty well sealed. Edited December 26, 2006 by welshpug Share this post Link to post Share on other sites
jackherer 543 Posted December 26, 2006 I've fitted a couple of the QEP wedges with two gaskets using the bolts Matt supplied, so unless he has changed the bolts they are plenty long enough... Share this post Link to post Share on other sites
jim21070 2 Posted December 26, 2006 I cant remember the manufacturer but on my friends 200SX we used a red silicon type stuff (specific to fitting exhausts) on the turbo elbow while the gasket was on order. it was still intact 3 weeks later when we got round to changing it, and was pretty well sealed. Yep. I used similar stuff on my son's 200SX Intercooler Elbows and it's still good. It's Permatex Ultra Copper. This is bright orange. Expensive though. £7 a tube IIRC. This stuff is good to 800 degrees and is O2 Sensor safe. Share this post Link to post Share on other sites
James_m 0 Posted December 26, 2006 Thanks for the suggestions, i will look out for the permatex stuff. Wanted to double check on the bolt length's so took a few pics whilst i was at it.... And with no gaskets Do we think the bolts are even long enough with no gaskets? £70 for a metal plate, and bolts of the wrong length, value for money eh Share this post Link to post Share on other sites
welshpug 1,662 Posted December 26, 2006 definitely a DOH! moment there, just get out and buy yourself £2's worth of bolt. Share this post Link to post Share on other sites
tom_m 0 Posted December 26, 2006 well as welshpug says, go out and get yourself some new bolts but if its any help you can pick up loctite 5920 copper at halfrauds which i think is the stuff you are talking about Share this post Link to post Share on other sites
James_m 0 Posted December 26, 2006 well as welshpug says, go out and get yourself some new bolts but if its any help you can pick up loctite 5920 copper at halfrauds which i think is the stuff you are talking about Not really because i will use the gasket's now :seriousmode: Cheers, be good if they do, im now thinking it would be better to use sealent instead of the gaskets, and save a few mm in bulkhead clearance. Share this post Link to post Share on other sites
welshpug 1,662 Posted December 26, 2006 if they're the same as 8v studs they're M7, which is impossible to get anywhere but peugeot and here http://stores.ebay.co.uk/WVS-FASTENERS_METRIC-M7_W0QQfsubZ11 what's confused me though is why you're using bolts as I thought the manifolds use studs? which if they're STD length should be long enough? but I guess not if QEP supply bolts. But really your first point of action should be an email or call to QEP just to clarify how they are meant to be fitted and why the bolts are as short as pictured. Share this post Link to post Share on other sites
James_m 0 Posted December 26, 2006 Your correct that from the factory studs are used, these bolts are what is supplied from the QEP with the wedge. I tried ringing them today, but obviously its boxing day so closed. I shall try again tomorrow Share this post Link to post Share on other sites
jackherer 543 Posted December 27, 2006 Matt must have sent you the wrong bolts, those are clearly too short. just get out and buy yourself £2's worth of bolt. You can't use standard bolts, the ones QEP supply have been machined to match the supplied washers. Share this post Link to post Share on other sites
Guest Top_Cat Posted December 29, 2006 What is this QEP that you all are talking about?...i would need this type of plate and washers for my project too. Any info about them?..i would need mine to be shipped over to mee (i live in Finland). Share this post Link to post Share on other sites
welshpug 1,662 Posted December 29, 2006 QEP!! you may have spotted it in the top right hand corner!!! if its not there try a refresh or two, the main forum sponsor Share this post Link to post Share on other sites
Guest Top_Cat Posted December 29, 2006 QEP!! you may have spotted it in the top right hand corner!!! if its not there try a refresh or two, the main forum sponsor Thanks! I haven´t been on this forum for a while so...im a bit "out" Share this post Link to post Share on other sites
James_m 0 Posted December 30, 2006 A little update.... i could'nt get through to QEP due to the time of year, and the nut and bolt shop near to me was also closed. But i was desperate to get the engine in and running....., so i used the original studs. All was going well, until the very last stud on the far left where the thread in the head failed (crappy chocolote aluminium) cant be bothered though, im just going to leave it as it is, and if it leaks too badly(which im sure it will) it will be head off and have it helecoiled or whatever it is. Bloody cars Share this post Link to post Share on other sites
