crf450 0 1 Cars Posted December 21, 2006 I'm just replacing one of the stub axles on my 306 rear beam and while it was stripped down I thought I might bore the arm out to give the rear some neg camber. I've done a search and I think the SBC kit gives about degree one negative, does anyone know if this is about optimum for a track car? Thanks Martin. Share this post Link to post Share on other sites
Super Josh 4 Posted December 21, 2006 Don't know if the 1 degree of camber is optimum, but the SBC kit also gives a little toe-in too. Josh Share this post Link to post Share on other sites
nick 3 Posted December 21, 2006 (edited) Oi, stop pissing about with your own car and get my pistons done!! Nick Edited December 21, 2006 by nick Share this post Link to post Share on other sites
shine 0 Posted December 21, 2006 I've been running with -2,2 degr negative camber rear on my Gti. Don't know difference to -1 degr, but regarding to std it's, very stable at rear, tire temp is almost same inside/outside after heavy track driving, and tyre wear seems to be equal over contact area. When doing this mod I also added some to-in, about 2mm. This makes rear end less overstear. Share this post Link to post Share on other sites
niklas 1 Posted December 21, 2006 It depends a lot on the roll stiffness of the car, but imagine that most cars with mcpherson struts use upto -4 degrees in the front. Because of the way these beams work (with none camber gain) you want about the same camber in the rear as in the front! But measuring the tire temperature is really the only way to know for your car! Share this post Link to post Share on other sites
Henry Yorke 269 3 Cars Posted December 21, 2006 (edited) 309 GTI16's have -1 degree. Not sure how neg camber will impact the passive rear wheel steer on a GTI-6 as it may make it more snappy as the toe-in effectively alters mid corner under lead Edited December 21, 2006 by Henry Yorke Share this post Link to post Share on other sites
Powers 13 Posted December 21, 2006 Shine, how did you achieve those figures? Are you able to buy different stub axles in Norway? Thanks for the input. Share this post Link to post Share on other sites
cybernck 402 1 Cars Posted December 21, 2006 doesn't toe-in on the rear slow the car down a little bit? Share this post Link to post Share on other sites
James_R 3 Posted December 22, 2006 they used to run something like 3mm per rim toe-out on the rear wheels only, which greatly improved tyre heating and turn-in - hope that helps That's part of an e-mail from one of the engineers that built the 306 BTCC's cars. Share this post Link to post Share on other sites
phatgti 0 Posted December 22, 2006 I run 1mm toe out on my alfa to promote turn in - it's quite lairy on the first race lap until they get warm but if you can hold it then it's amazing. I run 2-3mm toe out on the front as well with -3 camber and between -.5 and -1 on the rear. Share this post Link to post Share on other sites
shine 0 Posted December 22, 2006 doesn't toe-in on the rear slow the car down a little bit? Yes, slow down/get a more neutral rear end. As other say, some to-out will help turn in. It's always difficult to find whats best. I've tried to get as much balance in the car, and I was statisfied with the rear end a little bit more stable/neutral. Share this post Link to post Share on other sites
shine 0 Posted December 22, 2006 Shine, how did you achieve those figures? Are you able to buy different stub axles in Norway? Thanks for the input. I've machined the rear end myself. Share this post Link to post Share on other sites
pdd144c 0 Posted December 31, 2006 You can buy the modified stubs from somewhere. Skip Brown kit is what I'm using on my car. Can't remember the price off the top of my head now... Share this post Link to post Share on other sites
crf450 0 1 Cars Posted December 31, 2006 Thanks for all the input chaps,as I have said I have the arms set up on the machine ATM waiting to be machined,the arm is set as standard with neg camber and toe in but not as much as some of you lot are running. Cheers Martin Share this post Link to post Share on other sites
