TB_205GTI 1 Posted December 19, 2006 (edited) Does anybody know the flow limitations on the XU10J4RS exhaust manifold? Also can someone tell me approx. where the CatCams 4903155 on a 2.3L TB'ed (50mm bodies) engine will make peak power? (assuming the trumpet length and the cam timing are ideal) Edited December 19, 2006 by TB_205GTI Share this post Link to post Share on other sites
PumaRacing 2 Posted December 19, 2006 Does anybody know the flow limitations on the XU10J4RS exhaust manifold? Also can someone tell me approx. where the CatCams 4903155 on a 2.3L TB'ed (50mm bodies) engine will make peak power? (assuming the trumpet length and the cam timing are ideal) No but I can tell you it doesn't have enough lift to make decent power. I'm trying to get something better designed at the moment. Share this post Link to post Share on other sites
TB_205GTI 1 Posted December 19, 2006 (edited) No but I can tell you it doesn't have enough lift to make decent power. I'm trying to get something better designed at the moment. The cam? It should give almost 230Bhp on that engine - given everything is set up properly. It's a mates car - he has a Naak ECU on it and went to Naak (Danish tuner) to get it mapped today, but the exhaust manifold could't flow enough for the engine so he is stuck with 207Bhp at 6.000 rpm at the moment. Too bad it should top a bit higher. The head is not a XU10J4RS, it's a XU10J4 (34.6mm inlet, 29.6mm exhaust) Edited December 19, 2006 by TB_205GTI Share this post Link to post Share on other sites
PumaRacing 2 Posted December 19, 2006 The cam? Yes. It only has 10mm lift. That's pretty grim. With the same duration and 11.5mm lift you could be looking at 5% extra power. That's a lot to chuck away on a 200 plus bhp engine. Share this post Link to post Share on other sites
TB_205GTI 1 Posted December 19, 2006 Yes. It only has 10mm lift. That's pretty grim. With the same duration and 11.5mm lift you could be looking at 5% extra power. That's a lot to chuck away on a 200 plus bhp engine. Yes it sure is! He first had a solid lifter cam, and ordered solid 16 lifters at CatCams (550 quid) - but the did not fit the XU10J4 head - CatCams refused to take them back as they had been fitted to the head. So no other option than to buy a "hydr." grind - just too bad he got that one :/ Share this post Link to post Share on other sites
petert 607 Posted December 19, 2006 Does anybody know the flow limitations on the XU10J4RS exhaust manifold? I'm not sure it's relevant to what you're trying to achieve, but have a look at the flow figures I posted in this thread. http://forum.205gtidrivers.com/index.php?s...mp;#entry591891 Share this post Link to post Share on other sites
petert 607 Posted December 20, 2006 Yes. It only has 10mm lift. That's pretty grim. With the same duration and 11.5mm lift you could be looking at 5% extra power. That's a lot to chuck away on a 200 plus bhp engine. Sounds good in theory, but it's been my experience that total lift is not that critical in a XU9J4/XU10J4 head with this state of tune. For example, two hydraulic cams, both 236 deg. @ 0.050", one 9.2mm total, the other 11.1mm, both make approximately the same power. Share this post Link to post Share on other sites
TB_205GTI 1 Posted December 20, 2006 petert: yes I saw them om Guy Croft's forum - good info. Share this post Link to post Share on other sites
Mattsav 1 Posted December 20, 2006 The 155 & 156 profiles are FIA Super Production profiles and are all duration and no lift. Not a lot of use unless you have to run to FIA specs. I'm waiting for them to put some more sensible profiles on the site for this engine. Maxi's running a Gti-6 ex manifold on his engine and making 216bhp (S16 head) but his is only a 2.1 Share this post Link to post Share on other sites
maxi 36 1 Cars Posted December 20, 2006 The 155 & 156 profiles are FIA Super Production profiles and are all duration and no lift. Not a lot of use unless you have to run to FIA specs. I'm waiting for them to put some more sensible profiles on the site for this engine. Maxi's running a Gti-6 ex manifold on his engine and making 216bhp (S16 head) but his is only a 2.1 Mi16 head Matt..... XU9J4 Mine did exceed 220BHP on its previous runs..... Maxi Share this post Link to post Share on other sites
Sandy 191 Posted December 20, 2006 I've known one be converted to 4-2-1 by cutting off the flange/collector and welding y-collectors and secondaries on. I don't know how well it worked, but it certainly looked good! Share this post Link to post Share on other sites
