pugbliss 0 Posted December 19, 2006 hey up right my car feels very lathargic (spelling) and lacking any real power untill say doing 70 mph + on the motorway then when the revs are high(ish) there seams to be loads of power and it pulls great!!!!! could this be down to having a dirty hole in the centre silencer of the exhaust??????? which i have by the way. Or could it just be its own little way of saying service me you tight ba*tard! Share this post Link to post Share on other sites
Richie-Van-GTi 73 2 Cars Posted December 19, 2006 probably down to the hole, could also be ignition timing. Share this post Link to post Share on other sites
wildejon 7 Posted December 21, 2006 Could be worth checking the vacuum advance? I know ppl say it makes no difference but it did to mine! 1 min of your time anyway. Dont do the suck test though, better to blow, you don't get loads of cr@p in your mouth that way! No innuendos please. Share this post Link to post Share on other sites
pugbliss 0 Posted December 21, 2006 how do i do this test???? Share this post Link to post Share on other sites
jim21070 2 Posted December 24, 2006 how do i do this test???? Easy! Disconnect the vacuum advance tube from the Throttle Body. It is on a brass spigot underneath and the tube goes to the vacuum advance canister on the distributor (dizzy). Its job is to advance the ignition timing under high inlet manifold vacuum conditions such as when cruising on a small throttle opening. It has a significant effect on fuel economy as well as performance. Get the disconnected end of the pipe between your lips and blow hard. You should not be able to blow through it and if all is well your cheeks should puff out and your face turn purple If you can blow through it, you either have a perished pipe or the vacuum canister is punctured. A working vacuum advance makes a tremendous difference. New canisters are not expensive and simple enough to fit. Whilst you're in that area, check the little hole in the top of the Throttle Body where the pipe from the oil filler cap conncets. This hole is very tiny but if blocked much the same symptoms will occur. Share this post Link to post Share on other sites
