scumbag 0 Posted December 18, 2006 I've unscrewed the blower from that three armed holder thing but it is still stuck fast! Are there any more screws? One arm on the blower is attached to bulkhead and i unscrewed the other 2 arms but it is stuck fast! Help! it's no fun being cold and steamed up! Share this post Link to post Share on other sites
easypug 0 Posted December 19, 2006 Give it a wiggle, should come out. It is only held in with 3 screws you are correct . Share this post Link to post Share on other sites
Edp 67 3 Cars Posted December 19, 2006 It probably needs a small lever bar in there to ease it out of the housing. It should then just drop down with gravity. Share this post Link to post Share on other sites
scumbag 0 Posted December 19, 2006 Ok I'll give it a whack tomorrow! i'll try and let you know how I get on! is the thermistor the bit the white plug clips into to the right of the fan? Also it looks like what would be pin 1 and 2 and connected i.e pin one has a red wire coming out which connects into pin 2! Could someone check and see if this is right Share this post Link to post Share on other sites
