Lillpete
Noise From Cv Diff? When Turning Left?
Lillpete
My 205 Mi (previously 1.6gti) has developed a strange grumbling sound rather like a wheel bearing has gone, however there is no play in either bearing and it only makes the noise when I turn left(even slightly) could it be an inner CV or maybe is the diff on it's way out??
Any idea's :huh:
Higgy
Check your brake hoses.
I had the same thing with full lock turning right. I found it to be the braided brake line hittting a wheel balance weight.
Higgy.
Lillpete
Thanks I'll check that, but it's got louder and starts making noise at anything even 1/10 of a turn from straight on so I think it's mechanical.
BTW am I right in thinking that the diff and gearbox share oil??
miamistu
That is correct :)
Lillpete
That is correct :)
good so there is definately oil in the diff :)
Batfink
check for play in your drivers side driveshaft
