John_B 11 Posted December 13, 2006 I had just sat in my car and was about to start it when I noticed all the indicators on the passenger side were constantly on (with ignition on or off). I've disconnected each indicator in turn and the other two still stay on. I've removed the relay but they were still on after this as well. Any ideas?, I'm so sick of this car now. I need it for work tomorrow. I don't want to cancel the appointment because I've done that 3 times already- you've guessed it because of this bloody car. Share this post Link to post Share on other sites
Edp 67 3 Cars Posted December 13, 2006 (edited) Must be something to do with the hazard light side of the circuit as even if the indicator stalk was faulty the light wouldn't stay on with the key taken out. I'm unsure if the hazard switch has its own relay, might be worth a check? Edited December 13, 2006 by Edp Share this post Link to post Share on other sites
Powers 13 Posted December 13, 2006 Disconnect the hazard warning switch. If you are still stuck Pm me. Share this post Link to post Share on other sites
John_B 11 Posted December 13, 2006 Thanks for the tips, I'll try this tomorrow morning. Share this post Link to post Share on other sites
pug_ham 244 3 Cars Posted December 13, 2006 Flasher relay stuck internally? Remove it from the fusebox. Graham. Share this post Link to post Share on other sites
John_B 11 Posted December 14, 2006 OK, I disconnected the battery overnight so that it wouldn't go flat and when I coneected it again the car was fine for a couple of hours. Then tonight the indicators stuck on again. I disconnected the hazard warning switch as Powers suggested but this made no difference. (Pugtorque thanks but I had tried disconnecting the relay already and it made no difference). But when I actually started the car they went off? So does this mean there's an intermittent short after the relay, after the group of left side indicator wires but before the split to individual left indicators? Anyone have a wiring diagram? The haynes manual is useless. Thanks. Share this post Link to post Share on other sites
pug_ham 244 3 Cars Posted December 15, 2006 Have you got an alarm which flashes the indicators when you set / unset it? Try removing the fuse & see if that turns them off next time it happens. If it doesn't then its a wiring fault imo, although removing the relay should do the same but the fusebox could be at fault. Could be a suspect earth point (next to each headlight on the front panel) but that usually shows up as indiactors that don't work with bulbs that are perfect. Have you fitted uprated bulbs? What Haynes have you got? Service & repair or workshop manual? Saying that I think they both have the same detail wiring diagrams in. Graham. Share this post Link to post Share on other sites
