kyepan
Track Width Differences - 1.6 1.9 309
Gaz, you could try Drivelink but I doubt they'll be cheap. :huh:
Sandy
  pugtorque said:
Hub spline? Looking on the parts cd it lists the same one for all XU engines (infact nearly all 309's). I've got some driveshafts from an XUD 309 & they fit my 1.9 GTi hubs perfectly. The main hub is also the same on most 309's. parts cd
Easy & like Miles says, better safe than sorry.
Forgive me, shoot me, hang me, etc. The Hubs are the same Graham, it's the bar shafts that are different between GTi/TD and non GTi/TD XU's on the 309. I got mixed up and posted bollocks with conviction. :huh:
Guest purpletoddy
im in the middle of my 205 mi rebuild and also using 309 wishbones and 309 rear beam.........i had both driveshafts side by side 309 and 205 and couldnt see any difference???? i compressed them and fully extended them and they still looked the same length......i didnt get a measuring tape out though!!!
309 GTi items are definately longer...
The difference is between the hub end & inner joint, the bit that runs behind the block is the same on all XU engined cars.
TBH though the difference isn't a mssive amount, 10-20mm imo.
