Richie-Van-GTi 74 2 Cars Posted December 10, 2006 Just been working on a friends gentry, its a phase 1.5 with later management (jetronic?) Anyway we cannot get it to fuel correctly, renewed the pump as it was a tad lazy and now it seems to either draastically over fuel or seriously under fuel. But working on itr has raised a few questions. Hopefully someone can answer all of the following 1) should the AFM be adjsutable? This one is and the code is 0280202097 which isnt the same as my 1.9 code. 2) is the lambda supposed to be a 3 wire job or 4? its got a 4 wire lambda connected to a 3 wire plug setup at the ECU loom end. 3) will an earlier motronic ECU fit the loom so we could just ditch the lamda and switch to a 1.9 AFM from a motronic? please help as much as possible so we can get this otherwise mint car running right. Share this post Link to post Share on other sites
Gentrix 2 1 Cars Posted December 10, 2006 Just been working on a friends gentry, its a phase 1.5 with later management (jetronic?) Anyway we cannot get it to fuel correctly, renewed the pump as it was a tad lazy and now it seems to either draastically over fuel or seriously under fuel. But working on itr has raised a few questions. Hopefully someone can answer all of the following 1) should the AFM be adjsutable? This one is and the code is 0280202097 which isnt the same as my 1.9 code. 2) is the lambda supposed to be a 3 wire job or 4? its got a 4 wire lambda connected to a 3 wire plug setup at the ECU loom end. 3) will an earlier motronic ECU fit the loom so we could just ditch the lamda and switch to a 1.9 AFM from a motronic? please help as much as possible so we can get this otherwise mint car running right. The lamda should be a 3 wire Lamda, but a 4 wire will do the job aswell, cause the 4th is only for ground. A Motronic ECU will not fit The AFM has a CO adjusting screw (allan key) but it won´t cause your troubles, if it´s out of adjust. check for airleaks, and if you have major overfuel, when check the watertemp. sensor on the head behind the distributor. It sits a bit further down and has a blue (full of black crap) 2 wire plug. Check the plug and check the 2 wires which go in the plug, that they did not clip out of the plug itself. You have to remove the rubberthingy on the plug to see... Share this post Link to post Share on other sites
Richie-Van-GTi 74 2 Cars Posted December 10, 2006 thanks for the info found out its got the jetronic ecu with code 0280000345, can anyone confirm this to be the right 1.9 ecu and the code on the afm above is correct? Share this post Link to post Share on other sites
Gentrix 2 1 Cars Posted December 10, 2006 (edited) 205 - Jetronic ending with 359 = 128PS ending with 345 = 102PS ending with 333, 321, 340 = 1.6 105PS 205 - Motronic ending with 162, 160 = 120PS that´s for the ECU´s and motronic 120ps = ending with 202 jetronic 128ps = ending with 109 jetronic 102ps = ending with 097 jetronic 105ps = ending with 056 for the AFM´s so everything seems fine for you andi Edited December 10, 2006 by Gentrix Share this post Link to post Share on other sites
Richie-Van-GTi 74 2 Cars Posted December 10, 2006 Sweet thanks for that, will get a new lambda ordered see if that cures it then Share this post Link to post Share on other sites
Gentrix 2 1 Cars Posted December 10, 2006 it should run nearly normal, but a bit high on the mpg, otherwise fine with the lamda disconnected. the only trouble with a shot lamda I had, was a warmstart kangorooing. I bet it´s the watertempsensor.. Share this post Link to post Share on other sites
Richie-Van-GTi 74 2 Cars Posted December 10, 2006 if it only over fueled I would suspect the ecu temp sensor as well but it goes from one extreme to the other whch suggest lambda to me.Ive got a spare temp sensor knocking about somewhere anyway so can always give it a try if lambda doesnt cure it. Share this post Link to post Share on other sites
Henry Yorke 269 3 Cars Posted December 10, 2006 I have spare AFM and ECU for one of these XU9J1/AZ (DFZ) engines if you get really stuck. Share this post Link to post Share on other sites
