matt205xs
Thermostat Housing
matt205xs
On the side of the thermostat housing is a double pinned sensor along with the coolant temp& sendor
ANyone tell me what this does, as i have no wires to connect to it and cant seem to see it does anything on the intsrument panel?
its a MI16 2.0 16V BTW With 8V loom
thanks
AFAIK it a dual water temp sender & temp warning switch (one I have is light grey).
Sonofsam recently posted which pin does what if you want to wire it in.
Graham.
matt205xs
this is a light grey but im using the other 2 connectors on the thermostat to control the temp and warning light,
is this right?
Hilgie
the double pinned one is for the ECU to sense watertemp afaik
