Guest BIG_G
205 Mi16 Conversion
Guest BIG_G
right i'm planing on doin a transplant 405 1.9 mi16 in to a 205 1.9 8v. what i need to know is
how far to go back with the wireing loom? will the sencers be the same? will the mi16 gear box fit with no probs?
also both cars have pas would it be easier taking it off the 205 and not haveing it?
cheers BIG_G
Guest BIG_G
oh yeah and do i need to wire anything in to the fuse box?
Please have a search as there's pages upon pages of info on this
dee205
Here's a head start for you Click me mofo
It's my thread on wiring. I used the 3row Mi loom. All wire numbers and what to do are there.
Most of my conversion has been posted so stick my username in the search and you should be able to get something useful.
Damien
P.S. I don't know why I took the time to do this... you can't even capitalise your sentences.. how are you going to convert a 205 to Mi power? :);)
5150maxie
cheers BIG_G
i used the 2 brown plugs inside the car under dash near steering column .theres loads of guides on here which is very help full.the mi16 gearbox will fit but you need to swap the selector arm,and you will need the crank sensor plug.i had trouble with it a bit ago if you search there is loads of info (thats what they all say but seriously its helped me loads)good look :)
Guest BIG_G
cheers for all the feed back people
Edited by BIG_G
