smckeown
New Kms Ecu For 2007
smckeown
just noticed on the KMS site:
New in 2007
There is a new management system in development. This new system contains the following features :
* Complete engine management system up to 10 cylinders
* Lambda-control self learning with standard or wide band sensors.
* Boost-control (gear independent)
* Launch-control (variable)
* Idle-control
* Power shift (separate delay and cut off time for each gear)
* A.L.S. (variable)
* Engine diagnostics
* 3 auxiliary outputs (shift-light, water injection, cooling fan etc.)
* Rpm limiter
* 2 Engineload sensors
* Analogue input (second lambda sensor, gearbox position sensor etc.)
* USB Interface
* Short-cut protected outputs
* 38-Channel 4Mb data logging
* Dual processor technology
* Connectors with gold-plated pins
Bet it will be significanty more expensive :D I'd love some data logging!
Edited by smckeown
