smckeown
Diy Anodising
smckeown
Has anyone had a go with DIY anodising ?
Just interested if anyone has given it a go..
jim21070
I see no reason why not..
have a read of this:
Anodising
So it looks like you place the item in Sulphuric Acid and pass a current through it a bit like electroplating. Pop a dye in it and have any colour you like.
Might require a bit of experimentation to get it right though.
What are you planning to anodidse?
smckeown
some good links here:
http://astro.neutral.org/anodise6.shtml
http://www.focuser.com/atm/anodize/anodize99.html
http://www.eee.bham.ac.uk/joness/simpan.htm
I'm going to anodise the ali trumpets spacersi'm making. I think i'll make some more and sell some on ebay to cover the cost of making my own.
Thinking of buying this kit http://www.caswelleurope.co.uk/anodise.htm
Sean
Guest rick03054
I looked into this a while ago although I was looking more into chroming and considered anodising too. You end up with all sorts of nasty by-products and a fair bit of hydrogen gas being produced, which is DANGEROUS! And the actual outlay to buy all the chemicals and hardware is quite high, especially for a one off.
You have to take into account a lot of factors like the concentrations of the chemicals (and temperature to go with the particular concentrations) in your solution and their resultant 'throwing power' which dictates how far away you should place the electrode. This is important because it dictates the thickness, hardness and strength of the oxide layer.
Safer than chroming and I think slightly better results can be achieved, but a LOT of hassle.
To be honest if it's just a couple of things you plan on doing I'd see about getting it done by an electroplating place. I went for a job as a chemist in one and the stuff they use is complicated and under tight controls.
A less controled environment may be perfectly suitable for your needs, my experiance was based on the industrial side.
If you decide to go for it though I'd be well interested in how you get on. :o
309PUG
Another option with a little less outlay is a kit from Frosts www.frost.co.uk basic 5ltr kit £100 colour is extra
Chris
smckeown
I found 2 professional anodisers in the yellow pages. One will do a set of trumpet spacers for £15 (just silver of black), another for £5 cash (good range of colours) :D
So that puts buying my own kit out the window then :D
So i'll have some shiney bits soon to show you :ph34r:
sonofsam
Sean
Save your money. Brillo pad = Brushed effect :D:D
..Nah, look forward to seeing them Anodized Sean :ph34r:
Ryan
A mate of mine from uni used a DIY anodising kit for some bike parts. They came out really well, but the dye didn't last (apparently good anodising dyes cost £££). Within about 2 months all the red parts had faded to pink and the black parts had turned green.
