pugpete1108
Be1 Clutch Arm Pin
pugpete1108
i have managed to loose the two pins that i had for the clutch arm on my be1 box , does anyone know the size of them so i can make another one failing that does anyone have a spare i can loose .. i mean use ;)
steve@cornwall
i have managed to loose the two pins that i had for the clutch arm on my be1 box , does anyone know the size of them so i can make another one failing that does anyone have a spare i can loose .. i mean use :o
length 40mm x diameter 7mm- still got a spare in the cubby hole, even though i changed to be3!
pugpete1108
cheers , is there a special metal they should be made of , or will any do?
pete
TVH
pete
Any will do except aluminium. I replaced the pin with a M8 bolt when the pin got lost while driving back home. I just don't understand why the pin has to be a separate item not solid with the arm.
Edited by TVH
Rob_the_Sparky
If you can, drill a small hole through it. Then use some welding wire through this and attached to something else to stop it falling off the car.
Rob
pugpete1108
Rob
i might well do that , as i am getting and engineer at work to do his magic on the lathe.
i didn't loose it whilst it was on the car though it was when i took the gearbox out , its probably in a box burried in the garage somewhere . but i suppose if the cable snaps then the pin is gonna fall out
