kenan
What Spacers Required For Et20 Offset
kenan
What spacers required for ET20 offset, they are from an Escort?
sonofsam
Well, Pug ET is 18 , so 2mm in your case. It would be a Shim rather than a spacer. Ford offset is usually bigger than that though, what is the centre bore measurement?
Edited by sonofsam
kenan
no idea, off ebay wil ask. What size bore am I looking for? Know somone with milling equipment so can get it reduced cheap :)
sonofsam
Peugeot : 65.1
Ford : 63.3
kenan
he has said they are 63 so need a little work
sonofsam
if your mates with the miller :) you could a set of shims made up wich included a 'spigot' ring adaptor.
Edited by sonofsam
kenan
A who what where?? they make all sorts of stuff like that but I know nothing LOL. Arn't shims like spacers???? yes I am this daft most the time
sonofsam
Thinking back on what I said, i dont know if its possoble yet lol It is sunday after all...
Usually a 20mm Hubcentric spacer for Ford wheels onto Peugeot hubs would include a section that was small
enough to fit into the ford wheel ( 63.3 ) and big enough to fit onto the Peugeot hub ( 65. ) or some times you can buy that section on its own with out spacer known as a 'spigot' ring adaptor.
But a shim is generally regarded as being a smaller thickness than a spacer.
You with me:D
had a few brews though and I cant figure out if a spigot ring on a shim is viable :)
Might have to take a rain check on that.
kenan
If I win the wheels I take them to him and say "Make em fit, else I won;t go away" which should do the trick. Thanks for the help :)
