kyepan
What Is The Plastic Thing
kyepan
Its about 4-6 inches above the sump on the cam belt end and has water pipes going into and out of it. Mine appears to have an oil leak.
James_R
The water distributoin block usually has one pipe out the side that goes round to the rad, and one or two out the top??
Erm shouldn't have an oil lak if it's that, there's no oil near it, would suggest that something higher is leakign on to it??
Get some pics up ;) say a thousand words
kyepan
-_- Yep your right. Pics needed. Will get some up. Thanks for the reply.
if its oil itll be a leaky cam cover gasket or cam cover bolt seals.
