CTI STU
Rev Counter Ticking?
CTI STU
My rev counter is Ticking? sounds like a old cvh engine with the tappets ticking away!!
Is there anything I can do? other than turning the radio up ;)
cybernck
hmm are you sure it's not the speedo that's clicking?
Daxed
Yeah speedo gets my vote too, cable driven and makes a noise when it gets unhappy. Have you got any speedo needle flicker / strange behaviour etc?
I thought i had a leaf or something stuck in the r/h air vent that was vibrating in the airflow, it's actualy the speedo cable playing up and the noise comes out the air vent.
Guest smokinslim
Either that or your odometer's got stuck, handy for saving a few miles now n then ;) I find jabbing the button a few times usually helps.
CTI STU
100% sure its the rev counter I stoped and reved the car and its def the rev counter, This is the fist 205 (had 7 now!) where the speedo dosent flicker/tick
Jrod
Mine did that when I got it.
Smacked the top of the dash (hard) and it went away for a while but came back.
Replaced clocks and it's gone. ;)
CaptainP
Mine also did this but whilst I had the dash out to replace an ignition barrel & dash lights I reseated it. Been fine for months now.
Edp
I have this in my Mi. Its not a loud tick but its annoying. It does have a new speedo cable so it cant be that. I think the cble isnt seated properly into the housing. They are a bitch to get at. My needle also flickers at low speeds which pisses me off.
