Tony_205 1 Posted December 1, 2006 Got the Pug on the road today for my lad, he's gone to the local Tesco and put 20quids worth of Super Unleaded Fuel in it, 3 miles down the road, the car has started spluttering in all gears, and after a while its got to the stage where it wont pull away in 1st gear now Car drives fine in reverse, this is the method we used to drive it home lol Ive added 8quids worth of standard unleaded into the tank, to try and dilute it. Ill go up and get some more unleaded in the morning and run the car from cold.. - Do you think this will cure the problem or should i drain the tank etc?? Any help much appreciated, Share this post Link to post Share on other sites
GazRallye 0 Posted December 1, 2006 Are you sure thats the problem? I put super unleaded in every once in a while and it runs ok! Share this post Link to post Share on other sites
j_turnell 137 3 Cars Posted December 1, 2006 Cant see this being the problem, was the ignition timing advanced atall??? Does it idle fine or constantly splutter, i'd check all the ignition components are ok. Share this post Link to post Share on other sites
welshpug 1,675 Posted December 1, 2006 sounds like a totally unrelated problem to me, my 205 runs purely on vpower or sainsburys super. Share this post Link to post Share on other sites
TurboSam 5 Posted December 1, 2006 (edited) agree with the others, unlikely to have anything to do with the super unleaded. is it misfiring or just coughing/spluttering? Edited December 1, 2006 by TurboSam Share this post Link to post Share on other sites
Ahl 4 Posted December 2, 2006 Maybe you got some bad fuel? Share this post Link to post Share on other sites
nick 3 Posted December 2, 2006 I've just read in PPC that Tesco 99 fuel came out top in an independant test. I'd also say that bad fuel is very unlikely. Nick Share this post Link to post Share on other sites
benje 0 Posted December 2, 2006 There was a thread over on pistonheads about some guy who filled his brand new Z/M4 with what i think it was BP ultimate. Turns out no one had used that particular pump for a while and he ended up with a tank full of sludge and water in it, obviously knackering it! Share this post Link to post Share on other sites
Ahl 4 Posted December 2, 2006 There was a thread over on pistonheads about some guy who filled his brand new Z/M4 with what i think it was BP ultimate. Turns out no one had used that particular pump for a while and he ended up with a tank full of sludge and water in it, obviously knackering it! Yeah, it does happen occasionally. I remember my mums car (and a load of others) had something similar a while back. It turns out that they had managed to get a load of water in the underground tank when it was being filled up. Share this post Link to post Share on other sites
lagonda 42 Posted December 2, 2006 Not unknown for petrol station tanks to have water in them. I had terrible trouble many years ago, car running badly all the time, changed all sorts of parts, made no difference. Happened to fill car at a different petrol station & car gradually started improving; it was water in their petrol. If you've had the car off the road for a while, it could just be condensation in the car's tank, although I don't know if that's likely with a plastic tank. Also ... are you sure it's not diesel that got put in? Happened to me in France, symptoms sound similar. Share this post Link to post Share on other sites
steve@cornwall 100 Posted December 2, 2006 But why would it drive ok backwards? earthing or fuel line problem which is relieved with the engine pulling forward slightly on reverse? Share this post Link to post Share on other sites
Guest BrainFluid Posted December 2, 2006 Yeah I'ld double check it wasnt Diesel he put in there.... Share this post Link to post Share on other sites
Tony_205 1 Posted December 2, 2006 Right, iv had a Peugeot Mechanic look at the car today. He undone the fuel feed from the injector rail and ticked the car over, he said the fuel being pumped through is DIESEL as it leaves an oily residue to the touch, wheras as petrol would evaporate. Now my lad said, he swears that he checked and put in Super Unleaded..... Tonight, he has been to tesco with his mate, and the pump he used is CONED OFF!!! This leads me to believe that there may be a slight possibility that there could have been diesel in the pump he used ??? So im unsure weather to call the RAC out tomorrow and get a report etc from them... Car is running s*it at the min, there is diesel all in the injectors etc, we've had the car ticking over all afternoon, to no avail as the full tank of unleaded hasnt cleared all the diesel out... Going to keep trying tomorrow though! Share this post Link to post Share on other sites
benje 0 Posted December 2, 2006 In that case then I'd badger the garage for some sort of compensation. Only difficulty being trying to prove you filled up at that pump! Share this post Link to post Share on other sites
Tony_205 1 Posted December 2, 2006 Tesco have advanced CCTV matey, Share this post Link to post Share on other sites
nick 3 Posted December 2, 2006 The pump number on is usually on the receipt. Nick Share this post Link to post Share on other sites
jackherer 543 Posted December 3, 2006 Car is running s*it at the min, there is diesel all in the injectors etc, we've had the car ticking over all afternoon, to no avail as the full tank of unleaded hasnt cleared all the diesel out... Going to keep trying tomorrow though! have you changed the fuel filter? if not get that done and it'll probably be fine. what 205 is this btw? is this in the wrong section? Share this post Link to post Share on other sites
lagonda 42 Posted December 6, 2006 Slight good news in this is that apparently diesel is quite good at clearing residues & crap out of the system. It follows therefore that it would be wise to change the filter once all the diesel has run through. Share this post Link to post Share on other sites
jackherer 543 Posted December 6, 2006 I assumed you had drained the tank, I wouldn't run diesel through knowingly. If you lift the rear seat base you can get access to the fuel pump... Share this post Link to post Share on other sites
stevec205gti 0 Posted December 6, 2006 I had the same problem with my local garage - I filled up with a tankful of unleaded and get a nice mix of diesel. Fortunately a guy I worked with knew of a woman that had exactly the same problem as she filled up the same night. Make sure you go and speak to the garage asap and find out if this has happened. I billed the garage for the tank of fuel, and the garage fee to drain the tank, change the filters, service etc - they were quite willing to pay for it as it was their mistake. Share this post Link to post Share on other sites
Guest BrainFluid Posted December 6, 2006 I really would'nt worry about proof. RAC picked you up 3 miles down the road from the petrol station, and you now know that diesel is what was put into the tank. Tesco has cctv that they keep for atleast a week. Did your lad pay card or cash? Did he draw any money out at the petrol station? The MOST important thing is to contact the station as soon as possible really. And I'm sure they will give you 'nearly' everything that you ask of them Good luck . I doubt that you will need it though!!! Share this post Link to post Share on other sites
