Bam
Errorcode Table For Turbo
Bam
hi,
i'm looking for error code table bosch 3.1 turbo.
has anyone this table? :)
cheers mik
sonofsam
I have never seen it on here TBH, Found the list for the Mi16, unsure if they are the same?
Also just found this:
PEUGEOT 306('97 onwards), 406(95-96), 605(96-97) fault codes
Fault code Fault location
015Z The system relay.
016Z The BPP(Brake pedal position) switch.
018Z Rotors of the wheel speed sensors.
024Z Rear left wheel speed sensor.
025Z Front right wheel speed sensor.
031Z Rear right wheel speed sensor.
032Z Front left wheel speed sensor.
033Z The signal of the wheel speed sensors.
042Z The valves of the hydraulic modulator solenoid.
044Z The valves of the hydraulic modulator solenoid.
051Z The valves of the hydraulic modulator solenoid.
052Z The valves of the hydraulic modulator solenoid.
053Z The pump motor.
055Z The ECU.
057Z The battery voltage.
087Z Fault with diagnosis output.
091Z The warning lamp.
095Z With the hydraulic connections.
096Z The connections of the wheel speed sensors are transposed.
097Z Is an external signal interference.
099Z No fault is found.
P1100 MAF (Mass Air Flow) sensor intermittent / Systems check not complete
P1101 MAF (Mass Air Flow) sensor Out of self test range
P1102 MAF (Mass Air Flow) sensor in range but lower than expected
P1103 MAF (Mass Air Flow) sensor in range but higher than expected
P1104 MAF (Mass Air Flow) ground malfunction
P1105 Dual alternator upper fault
P1106 Dual alternator lower fault / MAP (Manifold Absolute Pressure) sensor circuit Intermittent high voltage
P1107 Dual alternator lower circuit malfunction / MAP (Manifold Absolute Pressure) sensor circuit Intermittent low voltage (EDC15C2-Swirl solenoid valve)
P1108 Dual alternator battery lamp circuit malfunction / Baro to MAP (Manifold Absolute Pressure) sensor comparison too high
P1109 Intake air temperature (IAT) B sensor intermittent
P1110 Intake air temperature (IAT) sensor (D/C) open/short.
P1111 Intake air temperature (IAT) sensor circuit Intermittent high voltage
P1112 Intake air temperature (IAT) sensor circuit Intermittent low voltage
P1113 Intake air temperature (IAT) sensor circuit open/short
P1114 Engine coolant temperature (ECT) sensor circuit Intermittent low voltage / IAT - B sensor circuit low input
P1115 Engine coolant temperature (ECT) sensor circuit Intermittent high voltage / IAT - B sensor circuit high input
P1116 Engine coolant temperature (ECT) sensor out of range
P1117 Engine coolant temperature (ECT) sensor circuit Intermittent
P1118 Manifold absolute temperature sensor circuit Low input
P1119 Manifold absolute temperature sensor circuit High input
P1120 Throttle position sensor (TPS) out of range
P1121 Throttle position sensor (TPS) circuit Intermittent high voltage
P1122 Throttle position sensor (TPS) circuit Intermittent low voltage
P1123 Throttle position sensor (TPS) In range but higher than expected
P1124 Throttle position sensor (TPS) Out of self test range
P1125 Throttle position sensor (TPS) circuit Intermittent
P1126 Throttle position sensor (TPS) circuit (Narrow range) Malfunction
P1127 Exhaust not warm Downstream oxygen sensor
P1128 Upstream heated oxygen sensor (HO2S) Swapped
P1129 Downstream heated oxygen sensor (HO2S) Swapped
P1130 Lack of HO2S switching - Adaptive fuel at limit
P1131 Lack of HO2S switching - Sensor indicates lean
P1132 Lack of HO2S switching - Sensor indicated rich
P1133 HO2S 1 Insufficient switching
P1134 HO2S 1 Transition time ratio
P1135 Pedal position sensor circuit A Intermittent
P1136 Fan control circuit Malfunction
P1137 Lack of HO2S 2 switching - Sensor indicates lean
P1138 High pressure rail sensor fault / Lack of HO2S 2 switching - Sensor indicates rich
P1139 Water in fuel indicator circuit Malfunction
P1140 Water in fuel condition
P1141 Fuel restriction indicator circuit Malfunction
P1142 Fuel restriction Condition
P1143 Air assist control valve Range / Performance
P1144 Air assist control valve circuit Malfunction
P1145 Lucas DCN2 - Noise on the needle lift sensor. Incoherence
P1150 Lack of HO2S 21 switching - Adaptive fuel at limit
P1151 Lack of HO2S 21 switching - Sensor indicates lean
P1152 Lack of HO2S 21 switching - Sensor indicated rich
P1153 Bank 2 Fuel control shifted lean. MM6LP - Throttle stop learning. Malfunction
P1154 Bank 2 Fuel control shifted rich
P1155 Alternative fuel controller
P1156 Fuel select switch malfunction
P1157 Lack of HO2S 22 switching - Sensor indicates lean
P1158 Lack of HO2S 22 switching - Sensor indicates rich
P1159 Fuel stepper motor Malfunction
P1164 Fuel pressure sensor test
P1165 SID 803 - Fuel Pressure signal. Pressure change coherence.
P1167 Invalid test throttle not pressed (AL4 - Fault in pressure regulation - variation/recommendation)
P1168 Fuel rail sensor In range low failure
P1169 Fuel rail sensor In range high failure / EDC15C2-Condenser 1 voltage
P1170 Engine shut off (ESO) solenoid Fault / EDC15C2-Condenser 2 voltage
P1171 Rotor sensor Fault / EDC15C2-Engine stop test by injector cut-off
P1172 Rotor control Fault
P1173 Rotor calibration Fault
P1174 Cam sensor Fault
P1175 Cam control Fault
P1176 Cam calibration Fault
P1177 Synchronisation Fault
P1178 (open)
P1180 Fuel delivery system Malfunction - low
P1181 Fuel delivery system Malfunction - high
P1182 Fuel shut off solenoid Malfunction
P1183 Engine oil temperature circuit Malfunction
P1184 Engine oil temperature Out of self test range
P1185 Fuel pump temperature sensor (FTS) high
P1186 Fuel pump temperature sensor (FTS) low
P1187 Varient selection
P1188 Calibration memory fault
P1189 Pump speed signal Fault
P1190 Calibration resistor out of range
P1191 Key line voltage
P1192 Voltage external
P1193 EGR drive Overcurrent
P1194 ECU A/D converter
P1195 SCP HBCC Failed to Inititialise
P1196 Key off voltage high
P1197 Key off voltage low / Piezo-electric injector, power stage
P1198 Pump rotor control Underfuelling - SID801 - Diesel high pressure monitoring. Flow regulator at stop.
P1199 Fuel level Input circuit low
From Here
Good luck, its a huge list on that site..and on here :D:):)
Bam
@sam :unsure:
i'm not sure..is that table right???
have errorcode 54..
not sure what that is?!
mik
sonofsam
Not sure as I can not read XL spread sheet :)
What exactly does it say?
Bam
the xls table is in polish...
but a workmate is pole.
he has translated:
errorcode 54: test new ECU / knocksensor
(knocksensor) but dont think so.
mik
sonofsam
Ok, but can he translate the whole list and post it up for future reference :lol:
Do you have the knock sensor connected?
And if your ECU has detected knock it will limit the boost will it not?! ;)
