B1ack_Mi16
How To Read Faultcodes From S16
B1ack_Mi16
I tried the same method that I use on my Phase 1 405 mi16, but got no luck.
Anyone?
cybernck
that's odd, as my 405 T16 with Magneti Marelli ECU uses exactly the same procedure as my Bosch Motronic 205 GTI :blink:.
B1ack_Mi16
Hm.. Maybe I wired it in wrong then.
Wire 480 goes from ECU, to diagnostic socket and then to the instrument cluster.
I wired up this wire with a bulb, and a switch to earth (before the lamp).
So thought earthing the circiut for 3 seconds would start the procedure.
B1ack_Mi16
One more important thing.
Does anyone have the complete list of faultcodes and what they mean ?
Edited by B1ack_Mi16
sonofsam
You will get all the fault codes and what they mean if you were to buy a Draper fault code reader:)
A few lists do appear on the internet also.
This post by petert should help.
Graham.
