Matt Holley 11 Posted November 18, 2006 (edited) Hello I have been fitting am mi16 engine to my 205 and could do with a few pointers on where some wires go or if they are needed Does this go into the permenant live box by the battary? Blue wire with big spade conector Whats this? is it needed? Looks like afm plug but bigger plus a few extra wires Lastly I have three wires one is yellow and green witch I guess is earth, can I bolt this anywhere? and is the red or blue wire with it needed? Clicky Thanks Edited November 18, 2006 by matt holley Share this post Link to post Share on other sites
dee205 3 Posted November 18, 2006 Is the big afm looking plug not for the amplifer? Damien Share this post Link to post Share on other sites
Matt Holley 11 Posted November 18, 2006 I thought that on the way home but I think I connected it it as remember it not having a metel clip on it, but I could be wrong though, If the ignition amp plug is part of the injector loom then it defo isnt, it if its isnt part of that loom then it probably is Share this post Link to post Share on other sites
Ryan 99 Posted November 18, 2006 Thick blue wire -> Live distribution box Big plug -> Ignition Amp Thin brown near big plug -> Earth to the ign amp heatsink Not sure about the others... Share this post Link to post Share on other sites
dee205 3 Posted November 18, 2006 The amp plug is on the managment loom. I have the 405 loom so I can't look for you. I can't think of anywhere else it would be for. There should be a topic on the bx loom floating around the forum somewhere if you did a search as I recall reading some time ago. Damien Share this post Link to post Share on other sites
Matt Holley 11 Posted November 19, 2006 I have sorted this out now and it is now running. For anyone that wants to know the yellow wire with the amp plug went to a red wire that was ignition live The grey on went to the rev counter. One more question though. I have fitted my 1.9 starter motor and when is cranking it make a weird whining/ screeching noise has anyone else had this? Also the engine didnt come with an ingnition amp so I have plugged it in the my 1.9 gti one is there a down side to this or is it the same anyway? Thanks Share this post Link to post Share on other sites
PsychoSimon 0 Posted November 19, 2006 I had the screeching when i put my mi in, but it was wheen it was running. It was deffo the starter though but it cleared itself in time. Also the ignition amps are identical between 8v and 16v looms I had the screeching when i put my mi in, but it was wheen it was running. It was deffo the starter though but it cleared itself in time. Also the ignition amps are identical between 8v and 16v looms Share this post Link to post Share on other sites
Matt Holley 11 Posted November 20, 2006 Thanks simon I will have to see if it goes, its a hard noise to describe and almost sounds as if the starter is going to give up but it was fine on the 8 valve. Share this post Link to post Share on other sites
Rom 0 Posted November 20, 2006 Sorry for the hijack. But couldnt see the point in starting another thread. I started my conversion on friday, just some wiring left now. This 2 pin plug near the end, by the Amp plug. Has a thick yellow, and small green wire. If ive searched correctly, thats Ign 12v and tacho wires ? The small grey wire on old coil loom is what i connect to the green,But i was wondering what the small green coming out of the coil plug is? It has a factory fitted spade terminal on it. The yellow wire, if ive traced correctly, theres only 2 yellow wires on the bx loom. One running to the injectors, the other to the coil, so could i splice the Ign feed inside, by the ecu. Rather than at the plug near the amp ? The oil pressure gauge, lights up, but goes out instantly under cranking ? But im not convinced the system is fully primed,am i missing something here ? I dont want to try and start it if its not fully primed. Share this post Link to post Share on other sites
Matt Holley 11 Posted November 20, 2006 Im not quite sure what you need, Are you trying to find an ignition feed to go to the yellow wire by the ignition amp (end of the loom) if so you use wire number 2 on the under dash plugs its a thick red wire, when I traced this back it also powers up the relay for the fuel pump which in turn gives you a power output from the ecu feed for the fuel pump. I cant remember the small green but it is probably just for diagnostics Share this post Link to post Share on other sites
