Adnic69 0 Posted November 15, 2006 I did a compression test lastnight on the car, just to check things really. I got the following readings 1) 12.5 2) 12 3) 13.4 4) 14 all readings were in bar. Is this good, bad? From this how can you work out the compression ratio? If it helps engine spec is below and was rebuilt roughly 10,000 miles ago. Share this post Link to post Share on other sites
hengti 2 Posted November 15, 2006 that's a variation of between 175 and 200psi (bar x 14.5 to convert to psi) i'm no expert, but would have thought that they should be closer on a rebuilt engine - ? Share this post Link to post Share on other sites
ALEX 98 1 Cars Posted November 15, 2006 Did you remember to hold the throttle open during the test? Share this post Link to post Share on other sites
greig 0 Posted November 15, 2006 can you get a compression test kit from halfrauds etc? are they any good? Greig Share this post Link to post Share on other sites
Livelee 0 Posted November 15, 2006 can you get a compression test kit from halfrauds etc? are they any good? Greig I got mine from Halfords recently £18.99 I got between 155psi and 180psi on my mi16. Engine hot and throttle open. Share this post Link to post Share on other sites
Adnic69 0 Posted November 15, 2006 I did not hold the throttle open no. Share this post Link to post Share on other sites
ALEX 98 1 Cars Posted November 15, 2006 Yeah I always forget to do that too. You get slightly higher readings if you open the throttle Share this post Link to post Share on other sites
welshpug 1,657 Posted November 15, 2006 yup, throttle open, you get a vacuum if you dont hold it open and you get lower and inconsistent readings. and for others looking for compression testers theres a selection here from under £8!!! http://www.pvrdirect.co.uk/products.aspx?i...r3=Gauged+Tools Share this post Link to post Share on other sites
PumaRacing 2 Posted November 15, 2006 http://www.pumaracing.co.uk/comp.htm Share this post Link to post Share on other sites
