e30m3
Engine Mount Removal
e30m3
HI
I've bought some uprated engine mounts and am having problems working out how to remove the top engine mount, can anyone tell me how its done
cheers
sonofsam
smack it round with a chisel.Its a captive nut underneath.
acox99
i found an oil filter removal tool worked a treat
you could try making a tool as shown in the haynes manual, I've actually seen one in my local PSA specialist but they dont use it very often, hammer and chisel work better!
Guest rick03054
I think I was unlucky but when I did this using a hammer the captive nut ended up bursting its casing and spinning, I've thought this may have been because I was hitting it at an angle. If possible get the oil filter tool or just bear this in mind.
I take it you mean this kind of idea?
acox99
no i used one with a chain, wrapped it around, got some preasure behind it, and it come off easily.
sonofsam
^Good tip that.Wonder if a Bicycle Chain whip would work!?
if its long enough to wrap onto itself then quite possibly, but not many come with that much chain attached nowadays, but you can always add more ;)
