Bam 0 Posted November 12, 2006 hi, i'm not sure wich pin i need to connect K-light and rpm from 2.0 8v turbo. not sure...43 k-light...55 rpm?! any ideas? cheers Share this post Link to post Share on other sites
sonofsam 5 Posted November 12, 2006 RPM gauge wont work with stock set-up. All discussed here Would also search 'K' Light as it will list wire numbers etc... Share this post Link to post Share on other sites
Bam 0 Posted November 12, 2006 ... found something... cheers Share this post Link to post Share on other sites
sonofsam 5 Posted November 12, 2006 NIce find.Not seen that before.I take it by 'Calculatuer' it means ECU. Share this post Link to post Share on other sites
cybernck 403 1 Cars Posted November 13, 2006 that's correct. Share this post Link to post Share on other sites
Bam 0 Posted November 13, 2006 i'm not sure... i would try this with rpm. is it possible to connect pin4 (gti) to pin2 (turbo)...and rpm will run (and show half rpm) ? its neccesary to sold between a resistor(or else) ?! cheers mik Share this post Link to post Share on other sites
sonofsam 5 Posted November 13, 2006 Diagram here Mik:) Share this post Link to post Share on other sites
Bam 0 Posted November 13, 2006 @sonofsam thx for diagram...i know that one hm...i use the stock wiring from gti. (so the resistor tacho must exist?!) Share this post Link to post Share on other sites
sonofsam 5 Posted November 13, 2006 Well I guess you could be the first to found out:) Share this post Link to post Share on other sites
