Edp 67 3 Cars Posted November 11, 2006 I am currently building a 205 GTi6 and I'm trying to figure out the best option for the brake department. The car will be mainly for road use but you never know in the future a track day might happen. Its also going to be a standard GTi6 engine but again in the future who knows I am going to run full braided lines from the M/C straight to the 4 calipers. I am using a GTi6 front set up and a standard 1.9 rear set up. I want to lose the rear compensators and put a bias valve in the engine bay. I've just mocked up this little drawing to show what i'm thinking and thought I would see what your opinions are. I have done various searches and see Anthony is running without a bias or compensators and he says its fine but there is also the opinion of the rear locking and spinning out. In the drawing I would use a 1.6 M/C and T to the rear calipers. Cheers Ed Share this post Link to post Share on other sites
welshpug 1,675 Posted November 11, 2006 looks spot on, as you mentioned there are some not using any sort of compensator/bias valve, a bit dodgy IMO unless its a pure race car which will never carry any more than a navigator and spare wheel/toolkit as the amount of luggage/crap in the boot affects the balance of the car drastically. Share this post Link to post Share on other sites
Edp 67 3 Cars Posted November 13, 2006 Thanks for your opinion welshpug, i think thats the set up to go with as no one has disagreed Share this post Link to post Share on other sites
Martin W 0 Posted November 13, 2006 I was planning to loose the rear compensators as well and use a bias valve. It is a track car though so only ever has (or can) have 2 people in. Share this post Link to post Share on other sites
smighall 1 Posted November 13, 2006 That's how i've got mine setup fella. Although i'm using a 23.8mm MC Share this post Link to post Share on other sites
Martin W 0 Posted November 13, 2006 That's how i've got mine setup fella. Although i'm using a 23.8mm MC 23.8mm MC is the only way to go with GTI-6 calipers Share this post Link to post Share on other sites
Anthony 1,003 Posted November 14, 2006 looks spot on, as you mentioned there are some not using any sort of compensator/bias valve, a bit dodgy IMO unless its a pure race car which will never carry any more than a navigator and spare wheel/toolkit as the amount of luggage/crap in the boot affects the balance of the car drastically. Not dodgy at all in my experience - I've done just about every extreme with a GTi-6 front and uncompensatored rear setup, from wet and dry trackdays, to the daily-commuter through to lugging engines, beams and whatever else in the boot and never once had any problems... Share this post Link to post Share on other sites
Higgy 0 Posted November 14, 2006 Not dodgy at all in my experience - I've done just about every extreme with a GTi-6 front and uncompensatored rear setup, from wet and dry trackdays, to the daily-commuter through to lugging engines, beams and whatever else in the boot and never once had any problems... Here here. I've had no problems. Higgy. Share this post Link to post Share on other sites
Daxed 7 Posted December 13, 2006 Will the larger master cylinder fit with a GTI-6 lump? Share this post Link to post Share on other sites
Richie-Van-GTi 74 2 Cars Posted December 13, 2006 should fit, the overall dimensions dont really differ vastly, its the internals that differ. Share this post Link to post Share on other sites
funkymofo 0 Posted December 13, 2006 what car does the 23.8mm MC come off? Gti6 by any chance? And what exactly does a bias valve do? Sorry for the thread hi-jack but I'm doing the same project as you so might aswell use this opportunity to learn! Share this post Link to post Share on other sites
Anthony 1,003 Posted December 13, 2006 what car does the 23.8mm MC come off? Gti6 by any chance? Most people source them from a non-ABS 406, which are 4 port and bolt straight on if from a pre-1998 car. And what exactly does a bias valve do? Adjusts the front to rear brake bias - ie allows you to adjust how much braking the rear wheels do Share this post Link to post Share on other sites
funkymofo 0 Posted December 13, 2006 cheers, should of known the brake bias control from good old gran turismo. d'oh! Share this post Link to post Share on other sites
