jim205GTI 3 Posted November 6, 2006 Right having found several matching wire numbers on the glovebox brown multiplugs as on the plugs by the drivers footwell i am getting slightly confused. The car is an f reg so i know there is a good chance that it is a hybrid of old and new But where all the wires match, and i am sure from the drivers footwell plugs they all went off into the engine bay, i got a funny feeling a previous owner has changed the loom To work out which ones which would it be easier to work from the wires down from the dash clocks and see to which set of plugs it leads......... With the phase 1 where the sensors go through the passenger side would this include the alternator wire? On the later cars does some of the sensor loom pass throught the glovebox ( maybe via the fusebox ) then back to the drivers footwell I got a free day wednesday and i think i know what i will be doing Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted November 6, 2006 If you have the brown multiplugs for the engine loom (coil etc) in the drivers footwell I'd make the connections there. Quite a few of the connections originate at the fuse box which explains why you have them there as well. The guages, starter & alternator wires run through the left side on the earlier cars but if you have two brown multiplugs by the heater matrix it is possible one of them is for the sensor, starter & alternator loom. The sensor loom runs under the dash to the drivers footwell on later cars iirc. Graham. Share this post Link to post Share on other sites
jim205GTI 3 Posted November 6, 2006 Cool thank you!! i did think so but i just wanted to make sure wednesdays task is now set.....have to dig out the old soldering iron again the only plug which i could find coming out the passenger side was one which had 3 wires , red, blue and white but of course the numbers had rubbed off Share this post Link to post Share on other sites
