jerseypug
Exhaust Cam Pully For Power Steering
jerseypug
just putting the mi engine back in to the 205 again, i take it the pully on the exhaust cam that was previously used for the power steering pump is not needed for anything else. i have taken it off as i was worried about it cutting through the fuel return or electrics.
You can remove it fine with no worries :)
jerseypug
thanks for that. makes a little more room in the engine bay.
I take these off but I always refit the bolt and washer to prevent corrosion damage to the thread in the cam in case its ever needed again for any reason.
