clifton
2.0 Turbo, Considering It
clifton
im thinkin about puttin a 2.0 turbo in the 205, the engine is from a 605, does the engine drop straight in or do the mountings have to be changed and everything?
or is there any another engines that people will recommend that are easier to fit?
cheers ben
inferno
the SEARCH
button should be of some use to you! many of us have done similar conversions and theres a whole heap of info readily available! get the engine, itll fit.
sonofsam
Get it.Fit it.Rag the tits out of it, especially in the cold wheather;)
Ant
Check the engine code !! - Earlier 605s have the lower powered 140 BHP engine. Code is just above the sump under tha starter
Regards
Ant
tom_m
Regards
Ant
that just means they are lower compression adn you get to shove more boost down its neck :rolleyes:
inferno
  tom_m said:
that just means they are lower compression adn you get to shove more boost down its neck :)
mental note to buy a bleed valve for my cti and "shove more boost down it"!
Ant
dont forget u need the additional fueling before you wack the boost up - or it may result in nice melted pistons :)
johnrobertgordon
NO NO NO NO NO NO NO.............................
Bleed valves are s*ite, they are just a rough bodge!
besides the car is mapped for the current boost and so if you add more boost you will just ge pinking on full boost, trust me, i know! :)
clifton
so im guessing you think its worth getting the engine, ill get in touch with the guy as soon as possible and buy it! what turbos have they got on?
sonofsam
T25 mate..but with an iffy flange.HAHAHA, so you cant put any other Turbo on there without upgrading to a TT manifold or similar, but dont let that put you off;)
