B1LLY
Front Valance
B1LLY
bought a front valance other day so have sprayed it up ready to replace old cracked one
am i right in thinking you got to remove the bumper in order to remove valance
tried to remove the bumper earlier today and failed miserably snapping 1 bolt rounding off another etc
looked at some of the bolts holding it onto the bumper and they are just as bad
so is it best for me just to rip the valance off as i wont need it
kate205gti
noo leave the bumper on - thats the hard bit! valance should be attached to the bumper by 6ish bolts (or most likely zipties), undo/snap off the bolts and ziptie the new valance on jobs a goodun :rolleyes:
B1LLY
thanks
i am leaving the bumper on as ive just sprayed it black
ill have another go tomorrow
cheeers
steve@cornwall
thanks
cheeers
Bolt holes are MUCH more accessible with the headlights removed- unless you have3 a ramp to access underneath
jim205GTI
And don't you have to remove the full range driving lamps aswell to remove the valance :rolleyes:;)
steve@cornwall
And don't you have to remove the full range driving lamps aswell to remove the valance :rolleyes::)
Good point!- but remove the lamp using the (17mm?) bolt at the lamp base as the 10mm welded to the bracket will almost certainly shear!(lamp wiring plugs also easier with headlamps removed ;) )
