Guest donny206 Posted October 30, 2006 I know its not a 205 but i find you guys know alot on here so thought id give it a shot! I have swaped the whole box ie clutch accel and brake over on my 206 that had a hydraulic clutch setup to another one from a 206 that has a cable clutch and the brake is now very soft indeed and soft all the way to the floor, ive not changed anything but this, the brakes still work and lock up just very soft, as soft as the accel pedal! Any ideas? Share this post Link to post Share on other sites
Rippthrough 98 Posted October 30, 2006 donny206 said: I know its not a 205 but i find you guys know alot on here so thought id give it a shot!I have swaped the whole box ie clutch accel and brake over on my 206 that had a hydraulic clutch setup to another one from a 206 that has a cable clutch and the brake is now very soft indeed and soft all the way to the floor, ive not changed anything but this, the brakes still work and lock up just very soft, as soft as the accel pedal! Any ideas? Might need the mastercylinder/pedal linkage shimming up - the gap may be too large now. Share this post Link to post Share on other sites
Guest donny206 Posted October 30, 2006 Rippthrough said: Might need the mastercylinder/pedal linkage shimming up - the gap may be too large now. i was hoping someone may say this other then just bleed em! any idea how Share this post Link to post Share on other sites
Rippthrough 98 Posted October 30, 2006 (edited) donny206 said: i was hoping someone may say this other then just bleed em! any idea how Take the master cylinder off (be careful not to twist the brake pipes too much, and put some plastiguage or similar over the rod, put the cylinder back on, take it back off and check the thickness of the plastiguage. I'll be bugger if I can remember what the gap is supposed to be, but I adjusted mine until I could just feel the brakes binding when pushing the car (with the engine running) and then went back a touch and tried it from there. My adjusting locknut had seized so mines shimmed up with ally foil! If you go too far your brakes will drag and lock on. Edited October 30, 2006 by Rippthrough Share this post Link to post Share on other sites
