petesy71 0 Posted October 29, 2006 hi, i've been reading a lot of posts on idling problems, and one mentioned the screw holding the oil filler to the inlet manifold. i had a look today and discovered this hole and was wondering is it the one that was mentioned? with the engine running i can hear air rushing into this hole,however when i cover it up the car stalls, leading me to think that it's something else. any help much appreciated,thanks, pete. Share this post Link to post Share on other sites
welshpug 1,666 Posted October 29, 2006 if the throttle stop or air screw have been adjusted to compensate for the airleak it will stall when you remove the leaf, stick a suitable bolt in it and unsrew the air screw on the throttle body to achieve a suitable idle speed. You may well find that you need to adjust the air flow meter a little to compensate as it would have been adjusted higher to compensate as well. Share this post Link to post Share on other sites
petesy71 0 Posted October 29, 2006 if the throttle stop or air screw have been adjusted to compensate for the airleak it will stall when you remove the leaf, stick a suitable bolt in it and unsrew the air screw on the throttle body to achieve a suitable idle speed. You may well find that you need to adjust the air flow meter a little to compensate as it would have been adjusted higher to compensate as well. thanks welshpug, is the afm easy to adjust? Share this post Link to post Share on other sites
welshpug 1,666 Posted October 29, 2006 yes, but best to leave it till you find a friendly garage with a gastester, its just a 5mm allen key. basically set the throttle to spec, then adust air screw till its idling at roughly 900 rpm, then set afm. (CO% at idle should be 1.5 but anything up to 3% is acceptable for MOT purposes, lower than 1.5% and itll be a bit lean, higher and it'll be a bit rich and thirsty) Share this post Link to post Share on other sites
petesy71 0 Posted October 29, 2006 thanks a lot for the info mate, pete. Share this post Link to post Share on other sites
