Nathan
Fao: Anybody With A Turbo 205
Nathan
I'm thinking about putting a turbo in onto my engine (1.8 s16).
I will undertake virtually all the work myself (well maybe not all the wiring) and I was just wondering how much its likely to cost (ball park figure).
I don't want stupid power, hoping to run around 7-8psi so shouldn't need fancy pistons, but I will run a mappable ECU.
johnrobertgordon
Whats the standard CR on your engine?
sonofsam
Turbo kit for your engine is here I beleive http://www.dp-engineering.nl/EN/products/t...ponent_package/
Obviously you can do it cheaper with second hand parts:)
However for £500 ish you could buy and fit a XU10J2CTE like John and myself have...150hp straight out the box so to speak.
johnrobertgordon
The manifolds in them Dp kits are stunning, still yearning for the "love collector" for mine.
TEKNOPUG
I'd budget a grand minimum. You might me able to do it for less, but I'd reckon on £750 for manifold and turbo unless you can make the manifold yourself and get a cheap second hand turbo. Then there are the changes required to the engine management etc.
pdd144c
Emerald plus mapping £800
Turbo £500
Manifold £250?
Injectors (secong hand) £60
Intercooler £200
Pipework £200
Map sensor (second hand) £50
Thats just over £2000 already...
Standard internals will be fine if its mapped correctly.
Arahan
is that an offer? :D il give you £500 to do it to my 205! :)
TEKNOPUG
Turbo £500
Manifold £250?
Intercooler £200
Pipework £200
£400 for pipework and IC is a little overkill. You can buy a Cossie IC for less than £50 and source parts piping from other cars. But £400 is good price is you use brand new, custom parts.
sonofsam
I only paid £120 for that massive jap spec IC, and the IC pipework kit was just under £100 ..
pdd144c
Better to budget over than under...
johnrobertgordon
And super glue them together so that the first time you give the car some welly the boost blows them to bit...........Oh no sorry only a bunch of rip off twats would do that sort of thing.
tom_m
true dat, but i think a decent fanimold will cost you a bit more than 250 quid :blink:
Edited by tom_m
pdd144c
Thought 205 parts ones were around that price?
tom_m
aye, but they won't fit the 1.8 16v head, they are 8v only
pdd144c
That is true! DP prices then I guess...
sonofsam
Well, seeing as the notoriously expensive Ecosse charge just over £4k for this conversion.I still think your £500 is a bit shy -_-
Arahan
Well, seeing as the notoriously expensive Ecosse charge just over £4k for this conversion.I still think your £500 is a bit shy :P
haha! cheers anyway then! :) Im actually considering doing this conversion though, with a Xantia Activa engine, Im searching through all the old posts to see what parts I need, and how difficult the wiring will be! Would you sort the wiring for me? If you did yours that is! and for a price! ha!
sonofsam
Yeh I did my own wiring, can certainly have a look at yours for you when the time comes:) In all honesty though with the info on this forum you may want to crack at it yourself.not really that difficult.
Ant
Sams right. Everything you need is on here, and the conversion can be done to a cheap budget if you dont want to have lots of fancy bits. Mine owes me less that £100 for the parts
A cossie IC cost me £25
45 degree 2 1/2 inch pipe cost me £5
90 degree 2 1/2 inch pipe £10 each x 2
Loads of hoses from the scrappy - free, but i bet you could get them cheap
1 meter of 2 1/2 rubber hosing - £9
heat shrink wrap + solder £5
Cambelt - £9
Thats about it i think - Just do a search and you will find most answers :blush:
or ask :)
acox99
what sort of turbo manifolds are on the net for MI;s?
sonofsam
DP engineering, T16, DIY:)
