Sam 4 Posted October 26, 2006 Hi, Can anyone confirm the following dimensions for me for an S16 (XU10J4) engine: Block Height - I have 235.1mm but Black_Mi16 says 234.1mm here and 234.8mm here so I'm not sure. Pin Size - 23mm Standard Piston Height - 39.1mm Standard Rod Length - 152mm and the Piston sits 1mm down the bore at TDC If anyone could confirm/tell me the correct figures that would be good. I have Wiseco waiting Share this post Link to post Share on other sites
B1ack_Mi16 67 Posted October 26, 2006 Hi, Can anyone confirm the following dimensions for me for an S16 (XU10J4) engine: Block Height - I have 235.1mm but Black_Mi16 says 234.1mm here and 234.8mm here so I'm not sure. Pin Size - 23mm Standard Piston Height - 39.1mm Standard Rod Length - 152mm and the Piston sits 1mm down the bore at TDC If anyone could confirm/tell me the correct figures that would be good. I have Wiseco waiting The block is 235mm from crank centerline to deck. Get pistons that'll sit a little under deck (maybe just 0.1mm) so you can have the block skimmed, clean and nice. Share this post Link to post Share on other sites
petert 607 Posted October 26, 2006 I get 235.1mm. Couldn't they find my info from earlier in the year? Share this post Link to post Share on other sites
