Richie-Van-GTi 74 2 Cars Posted October 25, 2006 For some reason I cant find any info of use yet I know its on here somewhere. If I stick a be3 box in place of my be1 what exactly do I need? Im guessing cable and pedal but seem to remember the linkages are the same? is this right? Ive got issues with m,y 1.9 box (be1) and an MI clutch causing my clutch pedal to be a good 2 inch higher than the brake or accelerator. Any lower and I lose the bar out of it Share this post Link to post Share on other sites
welshpug 1,682 Posted October 25, 2006 IIRC there should be a spring holding the two lever arms toghether so the bar doesnt fall out. Share this post Link to post Share on other sites
steve@cornwall 100 Posted October 25, 2006 For some reason I cant find any info of use yet I know its on here somewhere.If I stick a be3 box in place of my be1 what exactly do I need? Im guessing cable and pedal but seem to remember the linkages are the same? is this right? Ive got issues with m,y 1.9 box (be1) and an MI clutch causing my clutch pedal to be a good 2 inch higher than the brake or accelerator. Any lower and I lose the bar out of it Plus be3 thrust bearing...but wouldn't it be a lot less hassle to make a longer bar from an old bolt or something? Share this post Link to post Share on other sites
Richie-Van-GTi 74 2 Cars Posted October 25, 2006 Ive got a new be3 bearing as Im using MI clutch, aslo got a be3 box and 99% I have a be3 cable somewhere. Main concern is the linkages. Share this post Link to post Share on other sites
Miles 331 1 Cars Posted October 25, 2006 The gear linkages are the same, Just need small adjustment for the different angle of one selector on the box Share this post Link to post Share on other sites
