acox99
106 Hubs On 205 Beam
acox99
am i right in thinking these fit onto a 1.9 rear beam? or am i being silly, just i thought i read they did somwhere.
tom_m
i'm pretty sure I remember Hilgie speculating about using 106 hubs on a 205 rear beam for a 4wd conversion, if memory serves that is...
Hilgie
Yeah I did. 106 base model front bearings + hubs fitted to modified 205 rear arms. Still working on this basically. Project hasn't been finished yet.
acox99
have you got any pics you could email me of how its coming along, im picking up my MIx4 rolling shell next tues so will be starting the project myself soon, how are you getting around the transfer box problem
Hilgie
No pics yet unfortunately, but can make some soon.
The gearbox and transferbox will be used just like in a normal Mi16x4 setup. The subframe needs to be modified to fit the propshaft
The reardiff will be mounted on a bracket. Driveshafts will be made from 2 parts, Mi16x4 on the diff side and 106 on the hubs side.
acox99
is the engine going to be standard, so not to knacker the transfer box, as they are prone to being weak. yeah would be good to see some pics when they are done. is it going to be a track or road car? Any idea what mods the sub frame needs, as i havnt researched into this yet? is it a fairly easy mod with the use of a welder?
Hilgie
it's going to be a road car with around 350 bhp
XUD11 bottomend, with Mi16 head and GT28RS turbo.
acox99
sounds like its going to one hell of a car when its done. How do front hubs attach to the rear beam? sorry for all the questions, and will 106 driveshafts take the amount of torque you will be putting through them
efy2bjg
I would have thought that the driveshafts would be fine as each one is only taking a 1/4 of the engine torque instead of 1/2 in a 2wd setup?
Ben
Ben
if only one wheel has traction then 100% of available torque will be transmitted to that wheel...
efy2bjg
Good point! But can the transfer box transfer ALL the torque to either front or rear depending on traction?
Hilgie
The transferbox can't transfer ALL power to one wheel.
