GLPoomobile
Another Use For The Oil Plug Tool!
GLPoomobile
Was over at Teknopug's on Sunday so he could help me replace my drivers door (by which I mean he did most of the work and I stood around stroking my chin :D ).
Anyway, Andrew was having a spot of bother knocking the check strap pin out using various punch's and screw drivers etc. So I glanced down at my toll kit and saw the ever useful oil drain plug spanner. Hmmm, I pondered :P
'Here, give this ago, looks like it could work' I said.
So he positioned one end over the pin, gave it a few knocks with the hammer and sure enough, job's a good un :D Is there no end to this tool's uses?
Whilst I'm here, did anyone else know that Pug changed the design of the tailgate hinges? I've got a tailgate from an F reg that has two bolt holes for each hinge in the door, whereas the tailgate and hinges on my H reg only use one bolt for each hinge. I wish we had spotted it before cutting the loom in half and taking the tailgate off ;)
boombang
at least it gave you something to have a little moan about :P
The plug tool is on my to buy list as no idea where mine is (probably with all the T55 Torx bits and the allen keys)
GLPoomobile
at least it gave you something to have a little moan about ;)
Oh piss off :P
Guest rick03054
at least it gave you something to have a little moan about :excl:
I just use a house door handle and the square rod that goes through to the other side. Does the job perfectly so I havn't felt the need to buy a proper one. And as it happens my drivers door is sagging, so it's door handle to the rescue again! :wacko:
