Bam
Shaftdrive Length
Bam
hi,
i'm looking for the length of the left/right shaftdrives from:
peugeot partner hdi etc.
peugeot expert hdi etc.
(with gearboxes Me5;ML5)
regards
Bam
from 309gti
left
length [mm] : 610
tooth Diff. : 24
tooth tire : 25
diameter 1 [mm] : 88
diameter [mm] : 27
diameter 1/diameter 2 [mm] : 26
______________________
right:
length [mm] : 850
tooth Diff. : 24
tooth tire : 25
diameter [mm] : 27
Edited by Bam
jonD6B
I know that the Pug Partner and probably the Expert are 306 derived if that helps at all. Perhaps the Pug306.net forum can answer this if no one on here can?
Edited by jonD6B
Bam
hm...have found something of 306 s16.
left:
Länge 630mm
tooth tire 25
tooth diff 24
right:
länge 880mm
tooth tire 25
tooth diff. 24
jonD6B
What is it that you're trying to achieve? Replacement, wheel camber? :)
Bam
hm...306 hdi has also be3 box.urx. :)
@jond6b
i have fitted my 309 with xu10j2te (2.0 turbo). i have modifed inlet/outlet manifold, turbo etc.
so its possible to get around 300bhp/ 400nm...think will get some troube with BE3 box.
its better to change to ML5 box -but shaftdrives are different,nothing fits.
i'm sure that the hdi's (partner) are fitted with ml5 boxes -but i don't know how long the driveshafts are.
(custom shafts... a lot of work. and daffy if they go bust).
i hope you understand ;)
mik
