tom pug 2 1 Cars Posted October 16, 2006 can anyone help i am baffled, the pug was kicking out white smoke so i replaced the inlet manifold gasket and cured the fault great i thought, now however the pug revs up to about 3500 rpm when started at cold, i have replaced the sad unit checked all the pipes etc but cant seem to cure the problem, once warm the pug idles at just a touch over 1000rpm as it should please help Share this post Link to post Share on other sites
inferno 1 Posted October 16, 2006 sounds like an airleak when u disturbed the inlet maybe? unusall causeof white smoke too :S Share this post Link to post Share on other sites
tom pug 2 1 Cars Posted October 16, 2006 sounds like an airleak when u disturbed the inlet maybe? unusall causeof white smoke too :Sthanks the white smoke i have been told is from the water leaking into the inlet from the poor seal from the gasket Share this post Link to post Share on other sites
jackherer 543 Posted October 16, 2006 the high revving is caused by a missing bolt on 8v inlets, on the side by the oil filler IIRC, although its a long time since I had an 8v. Share this post Link to post Share on other sites
tom pug 2 1 Cars Posted October 16, 2006 the high revving is caused by a missing bolt on 8v inlets, on the side by the oil filler IIRC, although its a long time since I had an 8v. thanks will have a look tomorrow cheers Share this post Link to post Share on other sites
tom pug 2 1 Cars Posted October 17, 2006 the high revving is caused by a missing bolt on 8v inlets, on the side by the oil filler IIRC, although its a long time since I had an 8v.Cheers just the ticket runs sweet as a nut now Share this post Link to post Share on other sites
