Mike Walker
Short Shifter
sonofsam
Yes that advert is a little misleading in my eyes.Those rods will not shorten the throw of your gearstick.Although you will get a discount with Constella if you mention you are a member on here.
You need a modified lever.The red part in picture below:
These can be made yourself DIY style : check out 205gti.com for details
Speak to Miles on this Forum if you wish to buy new, also woth checking the mounting point next to the red lever as this often works loose and also do a search this Topic came up last week with a few other companies names mentioned:))
Sam.
EDIT-Ah my mistake, that kit can include a shorter lever.
Edited by sonofsam
Mike Walker
Sam.
Cool, cheers for the info - where did you get that pic by the way?
