welshpug 1,666 Posted October 10, 2006 or rather loose and lost anyone know what size thread the stud for the dizzy is on an 8v 205? and even better does anyone have a spare one? I know it has a 12mm head if that helps! basically I think i might not have tightened it up enough last week as when i went to have another play with the timing (much better now) the lower nut which is a right pain to reach was missing along with the little plate Share this post Link to post Share on other sites
pug_life 0 Posted October 10, 2006 mine are 11mm heads???? not sure on thread size but m6/m7 comes to mind.... Share this post Link to post Share on other sites
welshpug 1,666 Posted October 10, 2006 sorry, they are 11mm as you said, M6 usually use 10mm heads though, and M7 is not very common at all in fastener stockists Share this post Link to post Share on other sites
welshpug 1,666 Posted October 12, 2006 right, its definitely M7 and peugeot no longer supply them tried citroen and they said not in stock can order, which is really odd as its the same part number and the same warehouse anyone got a spare nut i can have? Share this post Link to post Share on other sites
pug309twin40s 1 Posted October 12, 2006 i'll have a look for you mate. i should have plenty of nuts lying in my big box of nuts and bolts. Share this post Link to post Share on other sites
welshpug 1,666 Posted October 12, 2006 cheers paul, if you have the plate that goes under the nut thatd be great but if not i'll just use a large washer. Share this post Link to post Share on other sites
