Gtautotech
Cambelt 1.9 & 1.6 Gti
Gtautotech
Are 1.9 gti and 1.gti cambelt and tensioners interchagable with each other??
Obviously if they are id have to use the right tesinoer for the year of engine
They're all the same on 1.6 and 1.9 engines with the exception of the very late engines ;)
Guest rick03054
Yes 1.6 and 1.9 are the same, and if you have the (earlier) spring loaded tensioner you need the 113 tooth belt, if you have the (later) eccentric tensioner you need the 114 tooth belt.
Gtautotech
cool just bought 113 teethe belt and spring loaded tensioner for my 1.9 gti, but bottom end has gone and might be buying an F reg 1.6 CTI tonight so i can put the belt and tensioner on that instead, new belt and tensioner hasnt evene been on the road yet just started it up in the workshop three times
